getting g code into AXIS
6 years 5 months ago #168667 by bbsr_5a
Replied by bbsr_5a on topic getting g code into AXIS
the % at begin and end is not needed but a M2 or M30 is to be Programm end
without it will be an error to load
6 years 5 months ago #168685 by MaHa
Replied by MaHa on topic getting g code into AXIS
Just had a look at the different behaviour, ending a program with M2, M30 or enclosed by %.
At least the active G code is similar, after ending with M2 or M30, but reset to a state as described in the docs.
Enclosing the Code with %, F, Plane, M3, Offset and maybe more is keeping its programmed values.
I am not shure if it is still a problem, when using % in the main program and also in a called subroutine.
Ending M2
Ending M30
Enclosed with % %
6 years 5 months ago #168687 by tommylight
Replied by tommylight on topic getting g code into AXIS
@MaHa,
Thank you, i did not know that, but i use % only when writing gcode by hand to test stuff.
Regards,
Tom.
Time to create page: 0.342 seconds
