Touch Off default value for offset
5 years 1 month ago - 5 years 1 month ago #221279 by wdcnc
I have recently installed a laser pointer with an 'X' pattern on my Z axis.  This pointer is offset from the router bit on the X axis by about 3" and from the Y axis by about 2".  When I touch off on an axis, I have to manually enter these values to 4 decimal places (something like -2.9693).  This works fine but I'd rather not enter these values each time I touch off on the X and Y axis.
Has anyone modified the axis.py script to allow for a default value to be specified in the .ini file so the offsets don't have to be typed in when touching off to the workpiece?
Thanks in advance.
Last edit: 5 years 1 month ago by wdcnc. Reason: Added content.
5 years 1 month ago #221284 by tommylight
5 years 1 month ago #221285 by wdcnc
The machine is a homebuilt 3 axis gantry type.
Linuxcnc is 2.9 pre (and some long number) on Mint 19.3.
I'd really prefer not to have to give up screen real estate for a button.
5 years 1 month ago #221287 by wdcnc
Silly me, I didn't realize GladeVPC could run as a tab in axis. Looks like some piddling is in order. I need to get something working for a touchplate also so maybe I can integrate that.
5 years 1 month ago - 5 years 1 month ago #221517 by rodw
. doubled up.
Last edit: 5 years 1 month ago by rodw.
5 years 1 month ago #221518 by rodw
This is how I moved to the XY laser position using a gmocappy macro. Should work for you.
; Testfile go Laser position offset ; will jog the machine to a position to give O<laser_off> sub G21 G91 G0 X -40.685 Y -26.595 g10 l20 p0 x0 y0 O<laser_off> endsub M2
Jog to where you want to set 0,0 by the laser and press a button. Easy
Time to create page: 0.056 seconds
