Camera tab in Axis
4 years 7 months ago #238314 by Henk
Replied by Henk on topic Camera tab in Axis
Well, i got it working, not exactly sure why, but it works.
I changed the PC, it was way overdue anyway. Installed the buster ISO with 2.8, followed the instructions on the wiki, and got an error.
Then i installed glade the way you would if you wanted to do a glade vcp panel. and it works!
Henk
  • EndCNC
  • New Member
  • New Member
2 years 6 months ago #297683 by EndCNC
Replied by EndCNC on topic camview
Hello,
i have some questions about the camview tab in AXIS. I added this lines in my ini.
EMBED_TAB_NAME = CAM
EMBED_TAB_COMMAND = halcmd loadusr -Wn camera qtvcp -c camera -x {XID} -o size=700,700 -o rotincr=.0 cam_align
so far so good. Unfortunately I couldn't find any documentation about the additional options.
Is there a list for this? For example, what does -Wn mean?
It's working great so far, but I have to rotate the camera and can't find the option to do so. I just copied the lines from my ini together. So I'm a total noob image missing /media/kunena/emoticons/laughing.png
2 years 6 months ago #297687 by cmorley
Replied by cmorley on topic camview
-Wn is a halcmd switch (option) , not a qtvcp -switch.
It mean Wait for the Named component to load before continuing.
Sparse docs here:
linuxcnc.org/docs/stable/html/gui/qtvcp-...vcp:panels:cam-align
Rotating the image was just recently added to the master branch though, so unless you are using that it won't be easy to rotate the image.
Chris
The following user(s) said Thank You: EndCNC
  • EndCNC
  • New Member
  • New Member
2 years 6 months ago #297692 by EndCNC
Many thanks for the quick response. That helps me. Then I will first rotate the mount of my camera. At least I can do hardware image missing /media/kunena/emoticons/laughing.png
Have a nice day.
2 years 6 months ago #298427 by stz60
Replied by stz60 on topic camview
look on "Update auf 2.9.2"
schau mal auf "Update auf 2.9.2"
1 year 8 months ago - 1 year 8 months ago #321313 by timo
Replied by timo on topic camview
Last edit: 1 year 8 months ago by timo. Reason: deleted, formating issues (difficult)
