[SOLVED] How to change the view of the axes in AXIS?
  • Nest
  • Nest's Avatar Topic Author
  • Premium Member
  • Premium Member
13 May 2022 19:47 - 16 Jul 2022 20:21 #242907 by Nest
Hi everyone, when AXIS is opened the direction of the axes do not match my machine,
In AXIS the X axis is down and the Y is to the right
on my machine the Y is down and the X is to the right
the Home of my machine is on the left.
how can i change that view in AXIS to match my machine?
Thanks you so much
Last edit: 16 Jul 2022 20:21 by Nest.
13 May 2022 22:24 #242913 by tommylight
Replied by tommylight on topic How to change the view of the axes in AXIS?
Some pictures or drawings would help.
  • Nest
  • Premium Member
  • Premium Member
13 May 2022 22:56 #242918 by Nest
Ok
In this picture you can see the axis X, Y and Z, the axis Z it's right, but i want to change the place of axis X by axis Y and vice versa
It's possible?
14 May 2022 01:34 #242933 by cmorley
Replied by cmorley on topic How to change the view of the axes in AXIS?
You want to flip the model upside down?
Some lathe views flip the model.
There are some other views but you would need to modify AXIS to use them.
  • Nest
  • Premium Member
  • Premium Member
14 May 2022 08:08 #242945 by Nest
yes, i want to flip the view.
someone knows?
16 May 2022 17:46 - 16 May 2022 17:46 #243091 by Todd Zuercher
Replied by Todd Zuercher on topic How to change the view of the axes in AXIS?
Do you get the view you want if you select "Rotated Top view" in the "View" menu?
Last edit: 16 May 2022 17:46 by Todd Zuercher.
  • Nest
  • Premium Member
  • Premium Member
16 May 2022 18:38 #243094 by Nest
Hi, i can't see that option, i share the picture where you can see the options
16 May 2022 19:15 #243099 by Todd Zuercher
On your image you posted, the second choice from the top "Vista superior girada", or the 2nd view Icon choice in the Icon tool bar (the sideways Z).
  • Nest
  • Premium Member
  • Premium Member
16 May 2022 20:05 #243106 by Nest
these options change the view but do not change the axes
17 May 2022 23:18 #243219 by andypugh
Replied by andypugh on topic How to change the view of the axes in AXIS?
I am suspicious that your machine is set up wrong. The coordinate system should be right-handed or CAM software (at least) won't work.
You will get mirrored parts, at best.
Time to create page: 1.241 seconds
