manual-toolchange-with-tool-length-switch sim fails mill upgraded to 2.9.2
2 years 3 months ago - 2 years 3 months ago #304193 by seuchato
rodw and aciera
Thx for your support
Did as instructed, though I was already on "deb linuxcnc.org/ bookworm base 2.9-uspace ". Same result. So I chose a fresh install from linuxcnc.org/downloads/ , using www.linuxcnc.org/iso/linuxcnc_2.9.2-amd64.hybrid.iso . Still same result.
[Got a problem with the editor, so this post is spread over several messages, sorry]
Last edit: 2 years 3 months ago by seuchato.
2 years 3 months ago #304194 by seuchato
Attached my /etc/apt/sources.list
Was the same all the time and on all my linuxcnc pcs. Don't know, still the same :-(
...sim/axis/remap/manual-toolchange-with-tool-length-switch$ head -n 3 manualtoolchange.ini
[EMC]
VERSION = 1.1
MACHINE = manualtoolchange.ini
...sim/axis/remap/manual-toolchange-with-tool-length-switch$ head -n 5 manualtoolchange.ui
<?xml version="1.0"?>
<interface>
<requires lib="gtk+" version="2.16"/>
<!-- interface-requires gladevcp 0.0 -->
<!-- interface-naming-policy project-wide -->
It's actually the very same as on github ( github.com/LinuxCNC/linuxcnc/blob/master.../manualtoolchange.ui )
So, no joy, and I ask myself:
where do you guys get your " manualtoolchange.ui" from?
Could it be it is a library issue? Permissions? But if, where?
If you guys have it up running out of the box, it must be something very obvious.
Thx a ton for your help
Greez
chris
2 years 3 months ago #304198 by seuchato
... and finally synaptics screenshot, showing all linuxcnc relevant packages' versions
Greez
chris
2 years 3 months ago - 2 years 3 months ago #304218 by seuchato
Hi all
Meanwhile I made 3 fresh installs:
debian 10 (buster), LCNC V 2.8.4: manual-toolchange WORKS
debian 12 (bookworm), LCNC V 2.9.1: manual-toolchange NOT working
debian 12 (bookworm), LCNC V 2.9.2: manual-toolchange NOT working
can't believe I am the only one having this problem
greez
chris
2 years 3 months ago #304244 by seuchato
Tried to pin down version more accurately and got this:
LANG=C dpkg -l mc
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii mc 3:4.8.29-2 amd64 Midnight Commander - a powerful file manager
LANG=C dpkg -l linuxcnc
un linuxcnc <none> <none> (no description available)
So, for midnight commander I get a decent version number and apparently linuxcnc is not installed????
Now I am confused
greez
chris
2 years 3 months ago - 2 years 3 months ago #304309 by Aciera
'/sim/axis/remap/manual-toolchange-with-tool-length-switch' runs for me on a 2.9 build from February:
I just had some time to look into this again and a closer inspection of the 'lib/python/gladevcp' folder revealed that I had modified versions of 'hal_python.xml' and 'hal_widgets.py' files that seem to fix this error.
File Name: GTKbugfix.tar.gz
File Size:5.05 KB
Last edit: 2 years 3 months ago by Aciera. Reason: Cleanup the files and reattach
The following user(s) said Thank You: seuchato, DPFlex
Time to create page: 0.338 seconds
