Axis view options are not persistant between sessions. Any thoughts?
- chrisfischer
- Thank you received: 10
21 Jun 2025 21:52 #330670
by chrisfischer
Axis view options are not persistant between sessions. Any thoughts? was created by chrisfischer
Hello,
I am trying to find the answer to the question why do my axis view preferences not stay persistant between sessions.
Actually some options are persistant like show offsets or alpha blend program.
But some important ones are not like display inches (always opens to mm) and show pyvcp panel.
I have searched the forum and chatted with chatgpt for a few hours now and frustratedly cannot get my machine
to turn on with inches displayed. I have tried to make .axisrc file but that never seemed to do anything.
Does anybody have any ideas? Thanks.
- Thank you received: 2177
22 Jun 2025 05:26 #330679
Replied by Aciera on topic Axis view options are not persistant between sessions. Any thoughts?
I presume you are talking about settings in the ini file. Neither unit settings nor pyvcp panel setup should require an .axisrc file.
When you say the display always opens to mm do you mean the number of decimal places?
- cakeslob
- Thank you received: 280
22 Jun 2025 12:20 #330710
by cakeslob
Replied by cakeslob on topic Axis view options are not persistant between sessions. Any thoughts?
hes talking about some of the options in view menu are persistent across reboots and save settings with .axis_preference , but some options , like " Hide PYVCP" are not persistent, and pyvcp needs to be hidden every boot.
The inches/mm one should be something in ini file thought. there are default configs that load with inches, and some mm.
22 Jun 2025 13:34 - 22 Jun 2025 13:38 #330714
I see.
Looking at line 2968 makes me think that 'hide pyvcp' was simply not intended to be persistent by the original author:
github.com/LinuxCNC/linuxcnc/commit/6948...6d967654a7R250-R2968
Last edit: 22 Jun 2025 13:38 by Aciera.
- chrisfischer
23 Jun 2025 16:44 - 23 Jun 2025 16:46 #330779
by chrisfischer
Replied by chrisfischer on topic Axis view options are not persistant between sessions. Any thoughts?
Talking about having to drop this menu down and change every time. I thought i changed everything in the ini related to units (attached).
Last edit: 23 Jun 2025 16:46 by chrisfischer.
- Thank you received: 7504
23 Jun 2025 16:52 #330780
Replied by tommylight on topic Axis view options are not persistant between sessions. Any thoughts?
UNITS = INCH # issue a G20 at load
DEFAULT_UNITS = INCH # same as G20
Remove the comments from those two lines.
- chrisfischer
24 Jun 2025 23:52 #330847
by chrisfischer
Awe man I got excited it would be that easy. Alas, no change.
Thanks for the idea!
25 Jun 2025 04:45 - 25 Jun 2025 04:50 #330855
I'm not aware of a 'UNITS' or 'DEFAULT_UNITS' key:
linuxcnc.org/docs/stable/html/config/ini-config.html
same for 'GEOMETRY_UNITS'
[edit]
But I guess those lines come from this:
[edit]
Last edit: 25 Jun 2025 04:50 by Aciera.
- JT
- Thank you received: 616
27 Jun 2025 07:54 #330927
by JT
Replied by JT on topic Axis view options are not persistant between sessions. Any thoughts?
When I open the axis sim the units are inch, when I open the axis_mm sim the units are mm.
In the [TRAJ] section of axis the LINEAR_UNITS are inch and in the axis_mm the LINEAR_UNITS are mm.
JT
JT
- cakeslob
27 Jun 2025 20:51 #330944
by cakeslob
yeah that should be the only option he needs in the INI file, the one in [TRAJ] LINEAR UNITS
the ai shit up your ini file. you need to fix these sections. I dont know what angular inch U axis is or a linear spindle.
#*** AXIS_U *******************************
[AXIS_U]
UNITS = INCH
MAX_VELOCITY = 7
MAX_ACCELERATION = 20
MIN_LIMIT = -500
MAX_LIMIT = 500.0
[JOINT_3]
TYPE = ANGULAR
UNITS = INCH
HOME = 0.0
MIN_LIMIT = -500
MAX_LIMIT = 500.0
MAX_VELOCITY = 7
FERROR = 1000
MIN_FERROR = 1000
HOME_ABSOLUTE_ENCODER = 1
#*** SPINDLE *******************************
[AXIS_B]
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
[JOINT_4]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
MAX_VELOCITY = 25.0
FERROR = 1000
MIN_FERROR = 1000
HOME_ABSOLUTE_ENCODER = 1Please Log in or Create an account to join the conversation.
Time to create page: 0.152 seconds
