Using Axis as "stand alone" viewer ?
- grey1beard
Is there any way I can use axis to view the g-code I'm writing in the warmth of the house, on a separate system, Ubuntu 10.10, without having to install the whole shebang here ?
If not, what freeware might be available just to view the tool path of my code ?
Many thanks,
John (the old grumpy one:) )
- BigJohnT
- Thank you received: 1176
or use VirtualBox OSE and install the 8.04 livecd on that and just run the Axis sim.
- grey1beard
J.
- Thank you received: 5015
Why not ssh -X to your actual CNC machine and fire up Axis remotely? You then have your actual live config running, but with the screen display in the warmth.
(You can actually run the machine like that, but I am not sure I would recommend it)
- grey1beard
There is a slight drawback at the moment in getting both systems running at the same time. I've only configured the two systems to run on wired lans ,and at the moment the router is in the warm with me
It would mean running a lan cable through the snow via either a window or the back door, both potentially vetoed by SWMBO.
Please don't suggest changing to a wireless lan as that's another tin of worms to be put off for when I decide to go fishing .
Sorry I don't know what the ssh -X command means, but would be glad to know.
ssh lets you run a remote terminal window into your machine.
ssh -X lets X-windows apps run on the remote machine, but with their gui elements on the local machine.
That rather kills that idea then.
- grey1beard
You should be able to install the sim version AFAIK...........
That worked fine, John. I used my live cd of 8.04/emc2, and checked out my code.
Just as well I did !
Now I want to try the virtualbox route, to see if that's a more convenient method.
Is it possible to run just emc2 in the box, or do I need to have 8.04 in it as well ?
I'll find a "how to" for VirtualBox OSE, and what that entails, later
Come to that, can I just install the latest emc2 version in 10.10 ?
I don't need it to run as a cam, just to run Axis as above.
- BigJohnT
This seems to be a bit dated but
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?EMC2_Pure_Simulator
I ASSUME you can just change 2.3 to 2.4 and get the sim.
- BigJohnT
- grey1beard
I'll try this one first, John. The second one looks a bit deep just to stick my toe in.Hi John,
