2.9.4 Get the Open File dialog to include .NC files by default
  • mooser
  • Topic Author
  • Elite Member
  • Elite Member
10 months 3 weeks ago #339890 by mooser
Is there a setting somewhere that I can change to have files with a .NC extension show in the open file dialog box without have to keep selecting the All Files drop down?
Not exactly a big issue but seems like there should a setting be somewhere I can't find.
M
10 months 3 weeks ago #339898 by tommylight
Ini file in your configuration folder, there is a section there with what can be opened from LinuxCNC, so editing that file to include .nc should be all that is needed.
I think it is Filter section...
The following user(s) said Thank You: mooser
  • mooser
  • Topic Author
  • Elite Member
  • Elite Member
10 months 3 weeks ago #339934 by mooser
That's where I tried putting it but it didn't seem to work. I might have the format of the entry wrong, I'll play around with it again
  • mooser
  • Topic Author
  • Elite Member
  • Elite Member
10 months 3 weeks ago #339958 by mooser
Never occurred to me that it would be case sensitive.... My Mastercam is set to spits everything out in unppercase including the extension.
Many thanks for making me look at it again.
10 months 3 weeks ago - 10 months 3 weeks ago #339959 by tommylight
Everything in Linux is case sensitive, or i just can not think of anything that is not right now. :)
Edit:
You can add two lines for upper and lower case each, removes the need to keep track of how it was saved.
Last edit: 10 months 3 weeks ago by tommylight. Reason: more info
  • mooser
  • Topic Author
  • Elite Member
  • Elite Member
10 months 3 weeks ago #339961 by mooser
Yup, should have known better but I've spent too many years in windows world and when I go to do something quick it bites me every single time.
(still getting my feet wet with Linux)
10 months 3 weeks ago #339962 by rodw
Edit:
Linux file names are case sensitive but Windows filenames are case insensitive. Take the learning as you will need it again!
10 months 3 weeks ago #339964 by tommylight
10 months 3 weeks ago #339965 by rodw
ooops, quoting wrong post, Or did I think you were a noob? image missing /media/kunena/emoticons/cool.png
10 months 3 weeks ago #339966 by tommylight
Time to create page: 0.398 seconds
