pin 'pyvcp.xxxxx' does not exist
16 years 4 months ago - 16 years 4 months ago #3103 by grewgood
net myhalzpos <= halui.axis.2.pos-relative => pyvcp.my-z-position
The value from this expression does not update for tool length offset (G43 Hx) as the DRO values in the axis 3D viewer do. Anyone know how to do that?
Thanks,
Greg
Last edit: 16 years 4 months ago by grewgood.
9 years 7 months ago #90486 by Nondepietjes
Can sombody spot my problem. i'cant see/find it:
postgui_call_list.hal:4: Pin 'pyvcp.x-minus' does not exist
#connect the X pyVCP buttons
net jog-x-neg <= pyvcp.x-minus
net jog-x-pos <= pyvcp.x-plus
#connect the Z pyVCP buttons
net jog-z-neg <= pyvcp.z-minus
net jog-z-pos <= pyvcp.z-plus
#connect the pyVCP jog speed slider
#halui.jog-speed <= pyvcp.jog-speed
File Name: mypanel.xml
File Size:995 B
9 years 7 months ago #90488 by andypugh
How are you loading the pyvcp panel (what HAL command, and in which HAL file).
where is the postgui_call_list called from?
The following user(s) said Thank You: Nondepietjes
9 years 7 months ago #90490 by Nondepietjes
I hqve changed it to custom_postgui file now.
and i dont understand. i have made something for the spindle speed and that appears on my screen attached to axis. but when i ad it for the buttons that doesnt work.
File Name: custom_postgui.hal
File Size:463 B
File Name: MD5_IT_2017-03-29.hal
File Size:11.34 KB
File Name: MD5_IT_2017-03-29.ini
File Size:3.06 KB
File Name: mypanel_20...3-29.xml
File Size:995 B
File Name: spindlespeed.xml
File Size:282 B
9 years 7 months ago #90507 by andypugh
I don't think that Axis supports multiple PYVCP panels, you probably need to combine both XML files.
(If you comment out the PYVCP=spindlespeed in the INI then I think you will get the buttons but not the spindle display instead)
Time to create page: 0.062 seconds
