feed convertion
  • piasdom
  • piasdom's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Jun 2011 11:42 - 02 Jun 2011 11:45 #10260 by piasdom
Last edit: 02 Jun 2011 11:45 by piasdom.
  • piasdom
  • Platinum Member
  • Platinum Member
02 Jun 2011 11:45 - 02 Jun 2011 11:46 #10261 by piasdom
i have both (pyvcp and ini) set to relative. shouldn't they
be the same in axis ? g43 enabled
Last edit: 02 Jun 2011 11:46 by piasdom.
02 Jun 2011 11:52 #10262 by BigJohnT
Press the # key to toggle the Axis DRO display and see what you get...
  • piasdom
  • Platinum Member
  • Platinum Member
02 Jun 2011 12:06 - 02 Jun 2011 12:29 #10265 by piasdom
it switches between relative position and machine position.
i like relative because when i have offset(g10..g55), it show the relative(no offset = 0)
machine position shows the offset(offset = 1.9) and moves from there.
first way - g0 x1 y1 x and y move to 1
second - g0 x1 y1(g54 = 1.9) x moves to 2.9 and y move to 1
in the pic, z is suppose to be at -1.07. in axis that's what shown.
pyvcp panel shows .055. i would like to have a dro as in axis.
if that is possible.
Last edit: 02 Jun 2011 12:29 by piasdom.
  • piasdom
  • Platinum Member
  • Platinum Member
02 Jun 2011 14:35 #10267 by piasdom
also, i changed z from relative to feedback and commanded.
they all show the same. shouldn't they (at least one) be different ?
02 Jun 2011 16:59 #10268 by BigJohnT
If you have an offset in the current coordinate system yes they will be different.
  • piasdom
  • Platinum Member
  • Platinum Member
02 Jun 2011 17:04 #10270 by piasdom
Mai dats no good.
But thanks :)
Time to create page: 0.055 seconds
