HAL Power Laser
- diegoroman17
- Topic Author
14 years 3 months ago #22572
by diegoroman17
HAL Power Laser was created by diegoroman17
I have linuxcnc installed in a laser machine. I am developing a plugin to CorelDraw that permit configure the power min and power max of cut for each color in the drawing. I am using the algorithm of post processor for EMC2 to create the GCode file. With respect to Power Laser I not have a decision yet. I have think create a file with power mins and power max of each layer and give this information to hal for interpolate the power with the velocity Eg. if velocity is 0 -> P is Pmin if velocity is max -> P is Pmax. It is my idea but I dont know if this is possible in HAL. I dont know if is possible read other files of power laser with HAL. I dont know if is possible write any flag in the GCODE for indicate to HAL that read the next line of power laser file. I dont know if can exist a better option for my purpose. Please help me.
I actually control the power laser with Spindle commands with PWM output.
XY axis is with stepper motors.
Z axis dont move.
Dont exist any feedback (encoders,resolvers,etc).
Z axis dont move.
14 years 3 months ago #22582
by cncbasher
Replied by cncbasher on topic Re:HAL Power Laser
i presume this is for laser etching , rather than for cutting purposes ..
it's usual to use the spindle speed command to control the pwm to control a laser power output .
perhaps altering the feedrate velocity ,combined with as you suggest the spindle pwm level may work as you suggest .
the problem you may find is that gcode is read one line at a time , and therfore previous settings , may or may not be held
i'd be interested to know the outcome also
14 years 3 months ago #22628
Replied by andypugh on topic Re:HAL Power Laser
diegoroman17 wrote:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Rastering_With_A_Laser
But it doesn't seem very elegant to me.
I made a start on a HAL component that imported bitmap files directly, but didn't get very far with it.
There is some information on a scheme (Graster) to do this here:hal for interpolate the power with the velocity.
- diegoroman17
- Topic Author
14 years 3 months ago #22647
by diegoroman17
This info is very interesting. I am checking the code but this HAL don't interpolate the PWM output spindle. It can do that exist differences of engraver in the zones of acceleration and desceleration its because the laser is held longer in these areas until the desired velocity. However this code can serve as a basis for something more elaborate
Replied by diegoroman17 on topic Re:HAL Power Laser
- diegoroman17
- Topic Author
14 years 3 months ago #22648
by diegoroman17
Is not necessary altering the feedrate velocity. I plan obtain the actual velocity in hal with sqrt(dx^2+dy^2). With stream component in HAL read the power laser file and with this information interpolate the PWM to control the spindle (power laser).
- diegoroman17
- Topic Author
14 years 3 months ago #22658
by diegoroman17
Andy I saw a post between Zig and you in:
www.linuxcnc.org/index.php/russian/compo...9386&limit=6&start=6
and it give me any ideas.
It is possible generate G code to make straight lines (G0 and G1 combination) and combine its with M64/M65 for enable or disable laser(my source power laser have a Enable Pin) along the line. I think that it is possible because LinuxCNC have lookahead. At the begin I should set power of laser with S command. The period of acceleration and deceleration can be compensated with extra space in the axis of move. Its avoid that laser burn more this zones.
I think that with this idea is possible have a better solution. Its avoid to have that create a new hal component and read external mask file.
Time to create page: 0.123 seconds
