PWM Not Working on Mesa 7i49
- jsflanagan
Here is he first part of my HAL file (full file attached):
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hostmot2
loadrt hm2_7i43 config="firmware=hm2/7i43-4/SVRM6S.BIT num_encoders=0 num_pwmgens=6 num_3pwmgens=0 num_stepgens=0 num_resolvers=6"
setp hm2_7i43.0.pwmgen.pwm_frequency 24000
setp hm2_7i43.0.pwmgen.pdm_frequency 6000000
setp hm2_7i43.0.watchdog.timeout_ns 10000000
loadrt pid names=pid.x,pid.z,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt classicladder_rt numPhysInputs=15 numPhysOutputs=15 numS32in=10 numS32out=10 numFloatIn=10 numFloatOut=10
addf hm2_7i43.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf classicladder.0.refresh servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf hm2_7i43.0.write servo-thread
addf hm2_7i43.0.pet_watchdog servo-thread
# external output signals
#setp hm2_7i43.0.gpio.040.is_output true #RAISE TURRET AND INDEX 7i37-17
#net dout-01 hm2_7i43.0.gpio.040.out
#setp hm2_7i43.0.gpio.041.is_output true #TURRET STOP PAWL 7i37-18
#net dout-02 hm2_7i43.0.gpio.041.out
setp hm2_7i43.0.gpio.042.is_output true #MACHINE-IS-ENABLED --- FIRE 6CR PULL IN BIG ASS CONTACTOR TO POWER CABINET 7i37-18
net machine-is-enabled hm2_7i43.0.gpio.042.out
setp hm2_7i43.0.gpio.042.invert_output true
#setp hm2_7i43.0.gpio.019.is_output true
#net x-enable hm2_7i43.0.gpio.019.out
#setp hm2_7i43.0.gpio.019.invert_output true
# external input signals
net min-x <= hm2_7i43.0.gpio.029.in # --- MIN-X ---
net max-x <= hm2_7i43.0.gpio.030.in # --- MAX-X ---
net home-x <= hm2_7i43.0.gpio.031.in # --- HOME-X ---
net min-z <= hm2_7i43.0.gpio.033.in # --- MIN-Z ---
net max-z <= hm2_7i43.0.gpio.034.in # --- MAX-Z ---
net home-z <= hm2_7i43.0.gpio.035.in # --- HOME-Z ---
net probe-in <= hm2_7i43.0.gpio.037.in # --- PROBE-IN ---
net estop-ext <= hm2_7i43.0.gpio.038.in_not # --- ESTOP-EXT ---
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-output => pid.x.output
net x-pos-cmd => pid.x.command
net x-vel-fb => pid.x.feedback-deriv
net x-pos-fb => pid.x.feedback
# ---PWM Generator signals/setup---
setp hm2_7i43.0.pwmgen.03.output-type 2
setp hm2_7i43.0.pwmgen.03.scale [AXIS_0]OUTPUT_SCALE
net x-output => hm2_7i43.0.pwmgen.03.value
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out => hm2_7i43.0.pwmgen.03.enable ####DRIVE ENABLE PIN22 ENA3+ 8PL-5
# ---Resolver feedback signals/setup---
setp hm2_7i43.0.resolver.03.velocity-scale 1 # mptor speed in RPS
setp hm2_7i43.0.resolver.03.scale [AXIS_0]RESOLVER_SCALE
net x-pos-rawcounts <= hm2_7i43.0.resolver.03.rawcounts
net x-pos-fb <= hm2_7i43.0.resolver.03.position
net x-vel-fb <= hm2_7i43.0.resolver.03.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_7i43.0.resolver.03.index-enable
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net min-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
- Thank you received: 5291
net x-enable axis.0.amp-enable-out =>hm2_7i43.0.pwmgen.03.enable
needs to be changed to
net x-enable axis.0.amp-enable-out =>hm2_7i43.0.pwmgen.00.enable
(pwmgen.0 enable is the global PWM enable on the 7I49)
- jsflanagan
-Scott
- Thank you received: 5013
That being said I went to hook up my spindle resolver and found out it's actually an encoder. This is on an old Hardinge CHNC,
Is there a possibility of swapping that encoder for a resolver? You occcasionally see them (relatively) cheap on eBay.
Otherwise, the cheapest way to add an encoder counter might be a 7i73, though you would need to check the count-rate. And might need custom firmware to connect it.
- simon n.
we are almost done with the config for the CNC machine, we now just need to know how we can handle the resolvers from the 3 axis. Every signal between machine and PC works properly, just the resolver doesnt respond to us.
we found a c-programm from andy here:
github.com/araisrobo/linuxcnc/blob/maste...-hostmot2/resolver.c
but we don't really know where to put it and if we really need it.
we also dont know when the 7i49 sends out the driver voltage for the resolvers, we guess the variable "index-enable" have to be true to get the 7i49 sending the driver voltage(this is a I/O variable).
maybe there is a function missing?
When does the 7i49 start working, it is not explained in the manual, i'll write down our hal and ini file, maybe there is a mistake.
hal:
# Generated by PNCconf at Wed Jul 3 15:25:37 2013
# Änderungen an dieser Datei werden beim nächsten
# overwritten when you run PNCconf again
loadrt trivkins
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i22-1/SV12_7I48_7I49S.BIT num_encoders=3 num_pwmgens=3 num_3pwmgens=0 num_stepgens=0 num_resolvers=3"
setp hm2_5i22.0.pwmgen.pwm_frequency 24000
setp hm2_5i22.0.pwmgen.pdm_frequency 6000000
setp hm2_5i22.0.watchdog.timeout_ns 10000000
loadrt hal_parport cfg="0x0278 out"
loadrt pid names=pid.x,pid.y,pid.z
addf parport.0.read servo-thread
addf parport.0.write servo-thread
addf hm2_5i22.0.read servo-thread
addf pid.y.do-pid-calcs servo-thread
addf hm2_5i22.0.write servo-thread
addf hm2_5i22.0.pet_watchdog servo-thread
#X-Axis
net Endschalter_+x axis.0.pos-lim-sw-in <= hm2_5i22.0.gpio.074.in
net Endschalter_-x axis.0.neg-lim-sw-in <= hm2_5i22.0.gpio.073.in
net Verzögerung_x axis.0.home-sw-in <= hm2_5i22.0.gpio.077.in
#Y-Axis
net Endschalter_+y axis.1.pos-lim-sw-in <= hm2_5i22.0.gpio.080.in
net Endschalter_-y axis.1.neg-lim-sw-in <= hm2_5i22.0.gpio.079.in
net Verzögerung_y axis.1.home-sw-in <= hm2_5i22.0.gpio.082.in
#Z-Axis
net Endschalter_+z axis.2.pos-lim-sw-in <= hm2_5i22.0.gpio.083.in
net Endschalter_-z axis.2.neg-lim-sw-in <= hm2_5i22.0.gpio.084.in
net Verzögerung_z axis.2.home-sw-in <= hm2_5i22.0.gpio.086.in
# AXIS X
net x-vel-fb => pid.x.command-deriv
setp hm2_5i22.0.pwmgen.00.output-type 2
setp hm2_5i22.0.pwmgen.00.scale [AXIS_0]OUTPUT_SCALE
net x-output => hm2_5i22.0.pwmgen.00.value
net x-enable axis.0.amp-enable-out => hm2_5i22.0.pwmgen.00.enable
#Resolver feedack signal/setup--
setp hm2_5i22.0.resolver.00.velocity-scale 1 # mptor speed in RPS
setp hm2_5i22.0.resolver.00.scale [AXIS_0]RESOLVER_SCALE
net x-pos-rawcounts <= hm2_5i22.0.resolver.00.rawcounts
net x-pos-fb <= hm2_5i22.0.resolver.00.position
net x-vel-fb <= hm2_5i22.0.resolver.00.velocity
net x-index-enable axis.0.index-enable <=> hm2_5i22.0.resolver.00.index-enable
setp hm2_5i22.0.encoder.00.counter-mode 0
setp hm2_5i22.0.encoder.00.filter 1
setp hm2_5i22.0.encoder.00.index-invert 0
setp hm2_5i22.0.encoder.00.index-mask 0
setp hm2_5i22.0.encoder.00.index-mask-invert 0
setp hm2_5i22.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
#net x-pos-fb <= hm2_5i22.0.encoder.00.position
#net x-vel-fb <= hm2_5i22.0.encoder.00.velocity
#net x-pos-fb => axis.0.motor-pos-fb
#net x-index-enable axis.0.index-enable <=> hm2_5i22.0.encoder.00.index-enable
#net x-pos-rawcounts <= hm2_5i22.0.encoder.00.rawcounts
#net x-home-sw => axis.0.home-sw-in
#net x-neg-limit => axis.0.neg-lim-sw-in
#net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-output => pid.y.output
net y-pos-cmd => pid.y.command
net y-vel-fb => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
setp hm2_5i22.0.pwmgen.01.output-type 2
setp hm2_5i22.0.pwmgen.01.scale [AXIS_1]OUTPUT_SCALE
net y-output => hm2_5i22.0.pwmgen.01.value
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out => hm2_5i22.0.pwmgen.01.enable
setp hm2_5i22.0.resolver.01.velocity-scale 1 # mptor speed in RPS
setp hm2_5i22.0.resolver.01.scale [AXIS_1]RESOLVER_SCALE
net y-pos-rawcounts <= hm2_5i22.0.resolver.01.rawcounts
net y-pos-fb <= hm2_5i22.0.resolver.01.position
net y-vel-fb <= hm2_5i22.0.resolver.01.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_5i22.0.resolver.01.index-enable
setp hm2_5i22.0.encoder.01.counter-mode 0
setp hm2_5i22.0.encoder.01.filter 1
setp hm2_5i22.0.encoder.01.index-invert 0
setp hm2_5i22.0.encoder.01.index-mask 0
setp hm2_5i22.0.encoder.01.index-mask-invert 0
setp hm2_5i22.0.encoder.01.scale [AXIS_1]ENCODER_SCALE
#net y-pos-fb <= hm2_5i22.0.encoder.01.position
#net y-vel-fb <= hm2_5i22.0.encoder.01.velocity
#net y-pos-fb => axis.1.motor-pos-fb
#net y-index-enable axis.1.index-enable <=> hm2_5i22.0.encoder.01.index-enable
#net y-pos-rawcounts <= hm2_5i22.0.encoder.01.rawcounts
#setup Outputs
setp hm2_5i22.0.gpio.095.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.094.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.093.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.092.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.091.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.090.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.089.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.088.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.095.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.094.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.093.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.092.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.091.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.090.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.089.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.088.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.071.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.070.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.069.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.068.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.067.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.066.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.065.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.064.invert_output TRUE #Ausgang als Low-Aktiv definiert
setp hm2_5i22.0.gpio.071.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.070.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.069.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.068.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.067.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.066.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.065.is_output TRUE #Deklarieren das GPIO Ausgang ist
setp hm2_5i22.0.gpio.064.is_output TRUE #Deklarieren das GPIO Ausgang ist
#net y-home-sw => axis.1.home-sw-in
#net y-neg-limit => axis.1.neg-lim-sw-in
#net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-output => pid.z.output
net z-pos-cmd => pid.z.command
net z-vel-fb => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
setp hm2_5i22.0.pwmgen.02.output-type 2
setp hm2_5i22.0.pwmgen.02.scale [AXIS_2]OUTPUT_SCALE
net z-output => hm2_5i22.0.pwmgen.02.value
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out => hm2_5i22.0.pwmgen.02.enable
#setp hm2_5i22.0.resolver.02.velocity-scale 1 # mptor speed in RPS
#setp hm2_5i22.0.resolver.02.scale [AXIS_2]RESOLVER_SCALE
net z-pos-rawcounts <= hm2_5i22.0.resolver.02.rawcounts
net z-pos-fb <= hm2_5i22.0.resolver.02.position
net z-vel-fb <= hm2_5i22.0.resolver.02.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i22.0.resolver.02.index-enable
setp hm2_5i22.0.encoder.02.counter-mode 0
setp hm2_5i22.0.encoder.02.filter 1
setp hm2_5i22.0.encoder.02.index-invert 0
setp hm2_5i22.0.encoder.02.index-mask 0
setp hm2_5i22.0.encoder.02.index-mask-invert 0
setp hm2_5i22.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
#net z-pos-fb <= hm2_5i22.0.encoder.02.position
#net z-vel-fb <= hm2_5i22.0.encoder.02.velocity
#net z-pos-fb => axis.2.motor-pos-fb
#net z-index-enable axis.2.index-enable <=> hm2_5i22.0.encoder.02.index-enable
#net z-pos-rawcounts <= hm2_5i22.0.encoder.02.rawcounts
#net z-home-sw => axis.2.home-sw-in
#net z-neg-limit => axis.2.neg-lim-sw-in
#net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd <= motion.spindle-speed-out
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---toolchange signals for custom tool changer---
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-prepare-request <= iocontrol.0.tool-prepare
net tool-prepare-confirmed => iocontrol.0.tool-prepared
____________________________________________________________________________________________________________
ini:
[EMC]
MACHINE = CNC
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
PYVCP = Jog.xml
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 2000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i22
[HAL]
HALUI = halui
HALFILE = CNC.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
#POSTGUI_HALFILE = Jog.hal
HALUI = halui
[HALUI]
MDI_COMMAND = G53 G0 X0 Y0 Z0
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.17
MAX_LINEAR_VELOCITY = 1.67
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.667
MAX_ACCELERATION = 2.0
P = 5.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
RESOLVER_SCALE = .2
MAX_OUTPUT = 10.0
ENCODER_SCALE = 5000000.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 80.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
P = 1.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
RESOLVER_SCALE = .2
MAX_OUTPUT = 10.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 80.0
HOME_OFFSET = 0.0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
P = 1.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
RESOLVER_SCALE = .2
MAX_OUTPUT = 10.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 800.0
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
- cncbasher
- Thank you received: 288
depending on your needed configuration
Can you see the hm2_5i22.0.resolver.00.rawcounts (etc) signals changing if you open a Halmeter? (Machine->Hal Meter in the Axis interface)Every signal between machine and PC works properly, just the resolver doesnt respond to us.
That is part of LinuxCNC and should be autoatically loaded if the hm2_pci driver detects any resolvers.we found a c-programm from andy here:
The whole HAL file would fail to load if it _wasn't_ detecting the resolvers.
No, that pin is for homing to index or spindle-synchronised moves. It emulates the behaviour of an incremental encoder with a one pulse-per-rev track.we also dont know when the 7i49 sends out the driver voltage for the resolvers, we guess the variable "index-enable" have to be true to get the 7i49 sending the driver voltage(this is a I/O variable).
I think that the excitation signal starts as soon as the firmware loads. There is no "enable" pin for resolver www.linuxcnc.org/docs/html/man/man9/hostmot2.9.html#resolverWhen does the 7i49 start working, it is not explained in the manual,
you seem to be using a wrong bit file , you need to use one that has resolvers , see previous post i.e SVRM6S.BIT R=resolver
I think that SV12_7I48_7I49S is a special bitfile with both encoders and resolvers.
I wonder if perhaps the 7i48 and 7i49 are on the wrong connectors?
- simon n.
it should have been in the CNC machine with 7i49 thread in the genral questions section.
sorry my fault^^. now there is 2 times the same question
the 7i49 is on slot 2 of the FPGA
the 7i48 is on slot 3 of the FPGA
the 7i37 is on slot 4 of the FPGA
the 7i37 is on slot 5 of the FPGA
just as the bit/xml file from PCW told us.
best regards
Simon N.
the driver loads.
Can you attach a kernel log og a linuxcnc startup here?
heres how:
sudo dmesg -c
(start linuxcnc and then exit linuxcnc)
dmesg > log.txt
and post log.txt here
