MPG jogging using gui increments
- OT-CNC
- Thank you received: 75
05 Aug 2015 22:51 #61168
by OT-CNC
MPG jogging using gui increments was created by OT-CNC
New user here. I need your help with a simple MPG setup. I would like to modify hal so I can use the mouse selected jog increments in the axis gui for mpg control. Basically have the same increments that the keyboard jog arrows use be linked to my 2 mpgs. I don't have any external switches.
So far I have a basic configuration that works with my x and z lathe axis using 2 mpgs. The jog rate is set at a default .001" per detent.
TIA
OT
TIA
OT
- BigJohnT
- Thank you received: 1175
06 Aug 2015 06:07 #61181
by BigJohnT
Replied by BigJohnT on topic MPG jogging using gui increments
I don't think Axis has the jog amount as a pin but you could check in Show Hal Configuration. Short of that you could add a PyVCP panel and put a radio button there for you MPG.
JT
JT
- OT-CNC
06 Aug 2015 06:24 #61182
by OT-CNC
Replied by OT-CNC on topic MPG jogging using gui increments
JT thanks for the response. I'll check the hal config. Not sure I want to add a PyVCP panel. It may be more practical to put a physical selector switch next to the mpgs.
If I go that traditional route, do the units on the gui update to what is selected on the switch? Or is the MPG pendant handled as a separate item?
- cradek
- Thank you received: 9
06 Aug 2015 08:39 #61184
by cradek
Replied by cradek on topic MPG jogging using gui increments
AXIS has axisui.* hal pins that are exactly for this.
% halcmd show pin axisui
Component Pins:
Owner Type Dir Value Name
67 bit OUT FALSE axisui.jog.a
67 bit OUT FALSE axisui.jog.b
67 bit OUT FALSE axisui.jog.c
67 float OUT 0.001 axisui.jog.increment
67 bit OUT FALSE axisui.jog.u
67 bit OUT FALSE axisui.jog.v
67 bit OUT FALSE axisui.jog.w
67 bit OUT TRUE axisui.jog.x
67 bit OUT FALSE axisui.jog.y
67 bit OUT FALSE axisui.jog.z
67 bit IN FALSE axisui.notifications-clear
67 bit IN FALSE axisui.notifications-clear-error
67 bit IN FALSE axisui.notifications-clear-info
- OT-CNC
07 Aug 2015 19:43 #61205
by OT-CNC
Thanks for the reply cradek. Do you have an example of what I need to add to the HAL file to make this work?
- BigJohnT
08 Aug 2015 18:15 #61221
by BigJohnT
- OT-CNC
08 Aug 2015 22:52 #61225
by OT-CNC
I have looked at the manual and the code generated by pncconf.
Do I need to connect the axisui.jog.a etc to the mux components? Not fully following as I'm new to this. It seems all the examples use external selector switches. No?
- Thank you received: 4957
10 Aug 2015 19:20 #61269
You don't need the mux, as the selector is in the axis software.
You just need something like
Of course, you could choose a shorter name for the net, and put it all on the same line
You can then delete everything "upstream" of axis.0.jog-scale from the original config.
Replied by andypugh on topic MPG jogging using gui increments
net some_net_name_increment axisui.jog-increment
net some_net_name_increment axis.0.jog-scale
net some_net_name_increment axis.1.jog-scale
net some_net_name_increment axis.2.jog-scale
The following user(s) said Thank You: Delron
- OT-CNC
19 Aug 2015 03:18 #61535
by OT-CNC
andypugh, thanks for the feedback. I spent 2 hrs trying to make this work. I need a bit more guidance sorry.
So far this is what I have that works:
net x-jog-count <=hm2_5i25.0.7i84.0.0.enc0.count
setp axis.0.jog-vel-mode 0
net x-jog-enable => axis.0.jog-enable
net x-jog-count => axis.0.jog-counts
net selected-jog-incr =>axis.0.jog-scale
sets x-jog-enable true
sets selected-jog-incr .001
This is repeated for the other axis.
I tried net 0.005_ axisui.jog.increment =>axis.0.jog-scale in the above example in the scale line. I don't get movement.
19 Aug 2015 05:21 - 19 Aug 2015 05:21 #61537
That is a net line that creates a signal called "0.005_ axisui.jog.increment" and connects it to axis.0.jog-scale, which probably isn't exactly what you want.
Try "net gui_jog_increment axisui.jog.increment => axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale"
Last edit: 19 Aug 2015 05:21 by andypugh.
Time to create page: 0.229 seconds
