how to change motor spin directions?
- famus
22 Mar 2016 23:03 #72056
by famus
how to change motor spin directions? was created by famus
Hi, Can anyone teach me how to change the motor turning direction?
I am using halrun to execute a .hal file. I am able to turn the motor at the default positive direction. I tried to set the pin "stepgen.0.dir" to 1 but it is a pin and not writable. Thank you for your help!
-famus
-famus
- Thank you received: 1482
23 Mar 2016 07:43 - 23 Mar 2016 07:45 #72059
Replied by Todd Zuercher on topic how to change motor spin directions?
There are lots of ways to do this. For an axis joint, you can change the sign of the scale, or (on step/dir setups) you can invert the output pin on your direction signal (for a parallel port example if the dir output of the step gen you want to reverse is on pin 2, add the line "setp parport.0.pin-02-out-invert true" to your hal file). There are a few more ways in the software. Another way is to swap around a couple of wires between the motor and drive to revers its direction there.
Last edit: 23 Mar 2016 07:45 by Todd Zuercher.
The following user(s) said Thank You: famus
- famus
23 Mar 2016 16:38 #72071
by famus
Replied by famus on topic how to change motor spin directions?
Thank you, Todd!
How would you do it software-wise? Besides inverting parport pin-02?
I am interested in changing the stepgen.0.dir via a command or checkbox. I tried this:
net xdir => parport.0.pin-07-out
net xdir <= stepgen.0.dir
net stepgen.0.dir <= GUI.checkbox_ReverseDir
where GUI.checkbox_ReverseDir is a variable of a GUI checkbox.
- famus
24 Mar 2016 00:42 #72083
by famus
Todd, I tried "setp parport.0.pin-02-out-invert true" and it worked fine to reverse the direction. Thank you!
What I'd like to do is to have a button or checkbox in GUI (gladeVCP) to get the .hal file to reverse direction. I tried this but didn't work:
setp parport.0.pin-07-out-invert GUI.checkbox_ReverseDir
It complained that GUI.checkbox_ReverseDir "invalid for bit". But the parameter is a Boolean bit. Puzzled!
24 Mar 2016 08:15 #72088
The line should be:
net (your signal name) <= (output pin name) => (input pin name)
The signal name is an arbitrary name you create for this signal. So for your purpose the line should be something like this.
net reverse <= GUI.checkbox_ReverseDir => parport.0.pin-07-out-invert
However this might not work as parport.0.pin-07-out-invert is a parameter rather than an ordinary input pin. What exactly are you trying to accomplish? Maybe there is a better way we could suggest if we knew what you are doing?
- famus
24 Mar 2016 11:19 #72100
by famus
Thank you for replying, Todd!
I am trying to have an external input to my setup of three stepper motors to turn the motors. I'd like to have speed and direction control. So far, I am trying a simple GladeVCP GUI to have button to control speed and direction to learn about LinuxCNC HAL.
I first tried manipulating "stepgen.0.dir". Shouldn't it be a pin to control directions? It's a bit and low is positive, high is negative direction.
I will try what you suggested tonight.
Thank you!
Thank you!
24 Mar 2016 11:45 - 24 Mar 2016 11:46 #72103
The "stepgen.0.dir" pin is an output from the step generator that it uses to change the motors direction. If you are wanting to change the direction of movement it would be better to change the input to the step generator to make it move the motor in the direction you want. What you are trying to do will cause the stepgen to loose track of it's position.
Last edit: 24 Mar 2016 11:46 by Todd Zuercher.
- famus
24 Mar 2016 13:23 #72106
by famus
Ok. Then I should not directly manipulate "stepgen.0.dir".
I have a signal called "xdir" that's connected to "stepgen.0.dir" pin. I should be able to change "xdir".
I'll keep trying tonight.
Thank you!
Thank you!
- famus
25 Mar 2016 01:07 - 25 Mar 2016 01:08 #72127
by famus
Tried:
couldn't work because "GUI.checkbox_ReverseDir" is not a pin. How can I change signal "xdir" via a GUI variable? I guess I have to read more.
Thank you for the suggestion!
Last edit: 25 Mar 2016 01:08 by famus.
25 Mar 2016 16:06 #72157
The stepgen component can accept a velocity command (as opposed to the ordinary position command) via the pin stepgen.0.velocity-cmd. This input pin is a float, that you could connect an output float to directly from your ui. As to how to create a hal pin from your ui, that depends on what sort of ui you are trying to use.
A good place to start researching how to do this is here.
linuxcnc.org/docs/html/
Specifically the sections "User Interface Programming" and "HAL (Hardware Abstraction Layer)"
Thank you!
Time to create page: 0.221 seconds
