halcompile error
- joekline9
- Thank you received: 9
05 May 2016 15:52 - 05 May 2016 21:39 #74283
by joekline9
halcompile error was created by joekline9
I can't get halcompile to work for a userpace comp. See error below:
joe@Shermill:~$ sudo halcompile --install --userspace testusr.comp
File "/usr/bin/halcompile", line 1353, in <module>
main()
File "/usr/bin/halcompile", line 1322, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1192, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 417, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
I am on Debian Wheezy and linuxcnc 2.7.4
main()
Last edit: 05 May 2016 21:39 by joekline9.
- joekline9
06 May 2016 13:27 #74313
by joekline9
Well I found the problem. DOS style line endings.
I just had to do Save As in Gedit and choose Unix/Linux not windows Line endings.
It would be nice if Halcompile would just ignore the '/r' but............
Replied by joekline9 on topic halcompile error
- Thank you received: 1482
06 May 2016 14:32 #74315
Replied by Todd Zuercher on topic halcompile error
Be nicer if Microsoft would just use the same endings as every one else
- Thayloreing
- Thank you received: 3
22 May 2024 14:57 #301163
by Thayloreing
Replied by Thayloreing on topic halcompile error
Could you tell me how you can solve the problem? I'm trying to compile a component but it's giving me the same error, I'm a beginner if you could explain me step by step I'd really appreciate it
- Thank you received: 7504
22 May 2024 18:07 #301167
Replied by tommylight on topic halcompile error
The simple answer is
Do not use windows to edit machine files.
There should be some software that fixes such issues, but i have never used it so no idea what it is called, try searching google for
linux fix dos style endings
- Thank you received: 426
22 May 2024 20:05 #301176
Replied by Cant do this anymore bye all on topic halcompile error
Geany can fix those issues.
mcedit can do it, need to sudo apt install mc (mc is a great curses (text) based file manager, can also change ownership, permissions and much more)
dos2unix is a cli utility that can do it.
Couple of methods with sed source edoras.sdsu.edu/doc/sed-oneliners.html
TEXT CONVERSION AND SUBSTITUTION:
# IN UNIX ENVIRONMENT: convert DOS newlines (CR/LF) to Unix format
sed 's/.$//' # assumes that all lines end with CR/LF
sed 's/^M$//' # in bash/tcsh, press Ctrl-V then Ctrl-M
sed 's/\x0D$//' # gsed 3.02.80, but top script is easier
- Thayloreing
23 May 2024 21:01 #301275
by Thayloreing
I got the file on Github, the encoder.c from the original linuxcnc, I'm editing it, then this error appeared, but when I get the original code and try to reconpile it gives the same error, I haven't used Windows at any point
23 May 2024 21:12 #301278
That begs the question, how did you download the file?
Raw?
Raw?
- Thayloreing
23 May 2024 21:38 #301280
by Thayloreing
I copied the file and pasted it into a text file named encoder.comp
23 May 2024 21:44 #301281
OK, i thought so, so two options:
1 use the RAW button on github to download files
2 use a text editor to paste stuff to, not the wordpads and office suits, and not on windows except if using notepad++
The following user(s) said Thank You: Thayloreing
Time to create page: 0.205 seconds
