- Thank you received: 4
Yeah I could, but I want the higher speed. As is I can do about 7200rpm on my mill but I want to go even faster.andypugh wrote: Can you swap to a 1:1 ratio? Mesa (or Pico) hardware would still be able to cope.
rusmannx wrote: My encoder is quadrature, but it looks like I'm stuck with only using index until I can divide my resolution down. Or get another encoder which I prefer not to do.
andypugh wrote: I may have been unclear.
For threading and rigid tapping LinuxCNC requires a once-per-SPINDLE-rev pulse to the encoder counter. This is used to start the threading pass so that subsequent passes all line up.
If your index is from an encoder that is geared to the spindle then the index will not align with the work (in a lathe) or the tap (in a rigid-tapping mill). This might not matter to you on your machine, of course.
