how to add a delay to machine on/off button
5 years 9 months ago #195461 by Thods1222
It is hooked up now to the machine enable signal. I will have to see of there is a drive ready signal to tie into. This is an Acramatic 2100 retrofit and I was able to get the 7i71 and 7i70 cards to interface with the IDC50 connectors from the machine. I seem to remember a "machine ready" that is triggered on an input. If that will work, how do I hook the input pin to the output pin in hal? (Sorry for the noob question)
5 years 9 months ago #195469 by andypugh
Thods1222 wrote: If that will work, how do I hook the input pin to the output pin in hal?
If they are both present in hal, then just connect them to the same net.
either
net netname pin1 pin2
or
net netname pin2
net netname pin1
(ie, in any order and anywhere in any HAL file)
The following user(s) said Thank You: Thods1222
5 years 9 months ago #195477 by Thods1222
I will give that a shot to see how it helps.
Time to create page: 0.271 seconds
