Mpeg Pendant 6 axis. Axis A,B,C no move. Please help! CNC ver. 2.3.0
- Banda68
27 Jan 2017 23:52 #86811
by Banda68
Mpeg Pendant 6 axis. Axis A,B,C no move. Please help! CNC ver. 2.3.0 was created by Banda68
Hi, Linuxcnc forum !
I have this problem:
On my homemade mpeg pendant I have a rotative switch for select axis X,Y,Z,A,B,C
I checked several times my connections from the pendant to the DB25 male connector to the LPT2 port and all wires are well connected. For sure i respect each pin like the CUSTOM.hal file!! like below
I have this trouble:
If I select the position "X" axis i can see the moviment of "Y+Z" axis togheter contemporanely....
If I select the position "Y" axis i can see the moviment of "X+Z" axis togheter contemporanely....
If I select the position "Z" axis i can see the moviment of "Y+X" axis togheter contemporanely....
I can't see each axis move alone... always this trouble
The problem is too about axis "A, B, C," Those no move anytime moving the encoder whell.
I tested too the "Show Hal Configuration" menu > Pins> Parport.
Each input is well working and moving the 6 positions rotative switch i can see the led yellow led go to red color when i select the requested axis. So the input is well working. Never i have 2 or more input contemporanely now!!
net mpg-x axis.0.jog-enable <= parport.2.pin-04-in # AXIS X
net mpg-y axis.1.jog-enable <= parport.2.pin-05-in # AXIS Y
net mpg-z axis.2.jog-enable <= parport.2.pin-06-in # AXIS Z
net mpg-4 axis.3.jog-enable <= parport.2.pin-07-in # AXIS A
net mpg-5 axis.4.jog-enable <= parport.2.pin-12-in # AXIS B
net mpg-6 axis.5.jog-enable <= parport.2.pin-13-in #AXIS C
The strange is about the input X,Y,Z,A are well working in the test input "Watch" . Those going ON or OFF one by one separatly but the axis move togheter like i described above.
Please can You check my Custom.hal file if have any error or errors or you suggest to write in different files or sometings?
I think the mistake can be there because I try to set it for 6 axis starting from the MPEG Pendant sample on the user manual myself . So for sure i make some mistakes.... Please apologize me !!
This is my Custom.hal file at the last revision:
# START OF MY Custom.hal file
# Jog Pendant
loadrt encoder num_chan=1
loadrt mux4 count=1
loadrt mult2 count=1
addf encoder.capture-position servo-thread
addf encoder.update-counters base-thread
addf mux4.0 servo-thread
addf mult2.0 servo-thread
# If your MPG outputs a quadture signal per click set x4 to 1
# If your MPG puts out 1 pulse per click set x4 to 0
setp encoder.0.x4-mode 0
# For velocity mode, set n to 1
# In velocity mode the axis stops when dial is stopped even if that means
# the commanded motion is not completed,
# For position mode (the default), set n to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
# This must be set for each axis you want to behave other than default
setp axis.0.jog-vel-mode 0
setp axis.1.jog-vel-mode 0
setp axis.2.jog-vel-mode 0
setp axis.3.jog-vel-mode 0
setp axis.4.jog-vel-mode 0
setp axis.5.jog-vel-mode 0
# This sets the scale that will be used based on the input to the mux4
setp mux4.0.in0 0.1
setp mux4.0.in1 0.01
setp mux4.0.in2 0.001
#setp mult2.0.in3 1.00
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= parport.2.pin-09-in
net scale2 mux4.0.sel1 <= parport.2.pin-08-in
#net scale2 mux4.0.sel2 <= parport.2.pin-10-in BL
#net scale2 mux4.0.sel3 <= parport.2.pin-11-in BL
# The output from the mux4 is sent to each axis jog scale
net pend-scale axis.0.jog-scale <= mux4.0.out
net pend-scale axis.1.jog-scale
net pend-scale axis.2.jog-scale
#net pend-scale mult2.0.in1 BL
net rot-scale axis.3.jog-scale <= mult2.0.out #BL Asse rotativo A
net rot-scale axis.4.jog-scale <= mult2.0.out #BL Asse rotativo B
net rot-scale axis.5.jog-scale <= mult2.0.out #BL Asse rotativo C
# The MPG inputs
net mpg-a encoder.0.phase-A <= parport.2.pin-02-in
net mpg-b encoder.0.phase-B <= parport.2.pin-03-in
# The Axis select inputs
net pend-counts axis.0.jog-counts <= encoder.0.counts
net pend-counts axis.1.jog-counts
net pend-counts axis.2.jog-counts
net pend-counts axis.3.jog-counts
net pend-counts axis.4.jog-counts
net pend-counts axis.5.jog-counts
End of Custom.hal FILE
Please apologize me for the english no so perfect..
Many Thanks to You for your Courtesy!!
Kind Regards
Luciano
# Jog Pendant
loadrt mux4 count=1
setp mux4.0.in0 0.1
# The MPG inputs
Kind Regards
Luciano
28 Jan 2017 00:08 - 28 Jan 2017 00:09 #86813
I am fairly sure that Bright Yellow is ="true" and Dark Red = False. (This makes no sense, and confuses me). Check with a pin where you can be sure of the sense, like spindle-on,
Try:
Every parport pin has a companion pin called "...-not" with the opposite sense, for convenience. Note that this is a special alternate HAL pin, it isn't the case that -not is a generic HAL modifier function.
Replied by andypugh on topic Mpeg Pendant 6 axis. Axis A,B,C no move. Please help! CNC ver. 2.3.0
Try:
net mpg-x axis.0.jog-enable <= parport.2.pin-04-in-not # AXIS X
net mpg-y axis.1.jog-enable <= parport.2.pin-05-in-not # AXIS Y
net mpg-z axis.2.jog-enable <= parport.2.pin-06-in-not # AXIS Z
net mpg-4 axis.3.jog-enable <= parport.2.pin-07-in-not # AXIS A
net mpg-5 axis.4.jog-enable <= parport.2.pin-12-in-not # AXIS B
net mpg-6 axis.5.jog-enable <= parport.2.pin-13-in-not #AXIS CEvery parport pin has a companion pin called "...-not" with the opposite sense, for convenience. Note that this is a special alternate HAL pin, it isn't the case that -not is a generic HAL modifier function.
Last edit: 28 Jan 2017 00:09 by andypugh.
- Banda68
28 Jan 2017 00:19 #86814
by Banda68
Replied by Banda68 on topic Mpeg Pendant 6 axis. Axis A,B,C no move. Please help! CNC ver. 2.3.0
Dear Andypugh Many Thanks for your quick answer !!
I understand perfectly your suggestions.
I think just now i understand after your suggestion my mistake.
Just on monday morning i will check my machine just because now I'm not at home for the weekend.
So I will advise you soon is possible about the result of the test.
Many Thanks for your Courtesy!!
Luciano
Luciano
- Banda68
31 Jan 2017 21:59 #87100
by Banda68
Dear Andypugh,
I have tested my machine following your suggestions.
Finally now all is ok and mine 6 axis moving one for time just selecting the 6 position selector.
My error was the Ground well no refered on mpeg pendant.
Many Thanks for your great support.
Kind Regards
Luciano!!!
Kind Regards
Luciano!!!
Time to create page: 0.178 seconds
