Question about matrix_kb
9 years 8 months ago #87748 by Niko
Replied by Niko on topic Question about matrix_kb
I use mux components but the created hal pins are not correctly decoded .
This specific board has diodes on all inputs and was successfully used by the fanuc .
9 years 8 months ago #87754 by Niko
I got the outputs going with a primitive component .
It's far from elegant, but it works .
component demux; pin in bit in11; pin in bit in12; pin in bit in13; pin in bit in14; pin in bit in15; pin in bit in16; pin in bit in17; pin in bit in18; pin in bit in21; pin in bit in22; pin in bit in23; pin in bit in24; pin in bit in25; pin in bit in26; pin in bit in27; pin in bit in28; pin in bit in31; pin in bit in32; pin in bit in33; pin in bit in34; pin in bit in35; pin in bit in36; pin in bit in37; pin in bit in38; pin in bit in41; pin in bit in42; pin in bit in43; pin in bit in44; pin in bit in45; pin in bit in46; pin in bit in47; pin in bit in48; pin in bit in51; pin in bit in52; pin in bit in53; pin in bit in54; pin in bit in55; pin in bit in56; pin in bit in57; pin in bit in58; pin in bit strobe1; pin in bit strobe2; pin in bit strobe3; pin in bit strobe4; pin in bit strobe5; pin out bit out1; pin out bit out2; pin out bit out3; pin out bit out4; pin out bit out5; pin out bit out6; pin out bit out7; pin out bit out8; function _; license "GPL"; // indicates GPL v2 or later ;; FUNCTION(_) { if(strobe1) { out1 = in11; out2 = in12; out3 = in13; out4 = in14; out5 = in15; out6 = in16; out7 = in17; out8 = in18; } if(strobe2) { out1 = in21; out2 = in22; out3 = in23; out4 = in24; out5 = in25; out6 = in26; out7 = in27; out8 = in28; } if(strobe3) { out1 = in31; out2 = in32; out3 = in33; out4 = in34; out5 = in35; out6 = in36; out7 = in37; out8 = in38; } if(strobe4) { out1 = in41; out2 = in42; out3 = in43; out4 = in44; out5 = in45; out6 = in46; out7 = in47; out8 = in48; } if(strobe5) { out1 = in51; out2 = in52; out3 = in53; out4 = in54; out5 = in55; out6 = in56; out7 = in57; out8 = in58; } }
The following user(s) said Thank You: sinusvag
9 years 8 months ago #87755 by bkt
Replied by bkt on topic Question about matrix_kb
B) .. perfect!
I use a similar one (I named it simplychoice) for make simply choice bit/pin out from several input bit/pin condition ... work from 2012 everyday without any problem ....
If work no touch!!
Regards
Giorgio
9 years 8 months ago - 9 years 8 months ago #87805 by sinusvag
Replied by sinusvag on topic Question about matrix_kb
Niko,
Thanks for the information - I am learning LInuxCNC and one of my "thinking cases" is how to interface a panel similar to yours.
If you don't mind me asking - did you jot down some sketch (on paper) on the physical side of your solution? It would be a nice complement to the code abode. Many have talked about retrofitting old control panels but I haven't seen any thorough write-up.
Cheers Hans
Last edit: 9 years 8 months ago by sinusvag.
9 years 8 months ago #87828 by Niko
When I was trying to understand how the board worked I went through the schematic .
I didn't get it with all the details but enough to give me an idea of how it works .
I'll have to get a few shots of the paperwork .
Cheers
9 years 8 months ago - 9 years 8 months ago #88242 by Niko
[This is to give an idea of the original mori circuit board .
The output side uses D triggers as a one bit memory . At the time I didn't write down the IC numbers but the circuit speaks for itself .
For now it seems to work well with matrix_kb . I moved the selector switches to direct inputs and run it in a 4ms thread . Response is good .
Cheers
Nikolai
Last edit: 9 years 8 months ago by Niko.
