linuxcnc ethercat lcec issue
9 years 2 months ago #97046 by superbird688
Hi Dan.K
Please search swm-f45a which is a good example to use asdaa2 profile.
Cheers
9 years 2 months ago #97275 by dan.k
Replied by dan.k on topic linuxcnc ethercat lcec issue
Hi superbird,
thank you for information, I looked in the files and it helped me. But I have a question about xml file. Did you use it with DeASDA name only or with generic and defined PDOs by yourself? I have a problem because in dmesg I got a message that "Slave does not provide information about sync managers", even if I use generic xml with sync managers defined. Did you meet with this? Please, can you share with us your successful configuration for ASDA-A2-E?
Thank you very much
9 years 2 months ago #97691 by dan.k
Hi all,
I'm testing on Delta ASDA-A2-E 200W and if I try to setup with swm-fm45a example from Sascha Ittner, it shows me only information in dmesg that slave does not provide information about sync managers. I think it's problem of defining FMMU because in original XML they are defined and they are not in E2PROM. Is it possible to add somehow FMMU definition of FMMU to generic XML file? It does not work also with DeASDA.
Daniel
9 years 1 month ago #99468 by fupeama
Hi All.
I have same results as dan.k
dmesg shows "slave does not provide information about sync managers" sm2 and sm3.
I try generate my own xml file for generic driver with same result as with native asda driver.
I try setup fmmu in ethercat config but I dont know how.
Is there somebody who successfully run delta asda a2 E driver?
thanks
Martin
my configuration
rtail 3.4.9 debian wheezy
linuxcnc 2.7.11 (2.7.8)
igh ethercat compiled from source with debianize patch
linuxcnc-ethercat compiled from sittner git source
9 years 3 weeks ago #100083 by fupeama
Hi all,
I found solution, SII file in eeprom doesnt contain info about SM.
I wrote mi own SII file and now I am able to run driver.
Martin
File Name: Delta-asda.rar
File Size:215 B
9 years 6 hours ago #101168 by sqmathlete
Hi Fupeama,
I am having a similar problem. I tried to unrar the file but the file size is 0. Any chance you can re-post? Thanks in advance.
Kind Regards,
Dan
Time to create page: 0.214 seconds
