Speedcommand Modbus driver for An Altivar ATV71 VFD
9 years 7 months ago #89737 by christian99x
We are using the following module for controlling our VFD:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...ATV71_VFD_driver_atv
The link to the git is down, but it's available on another forum:
www.c-n-c.cz/viewtopic.php?f=34&t=4869
The problem is, that the start/stop command works, but the speed command doesn't (We had this working, so I know it's possible). I found out, that there are two different addresses for these two commands, but I don't know where to set it. I searched the settings of the VFD, but I could not find this parameter.
Any help appreciated - Thanks !
9 years 7 months ago #89774 by andypugh
Have you looked at the component code?
9 years 7 months ago - 9 years 7 months ago #89825 by christian99x
Yes - in the xls file with the atv parameters I can find:
CMD 16#2199 = 8601 (speed)
16#2135 = 8501 (frequency)
....and in the code I can find:
#define REG_CMD 0x2135 // Control Word CMD 8501 frequency
So I would say it's correct ....... but it's not working....
Do I have to set the address in the atv or is it fixed??
Last edit: 9 years 7 months ago by christian99x. Reason: correction
8 years 11 months ago #101680 by christian99x
I analyzed the problem further and I found out, that the atv_vfd module IS sending out a speed command. Unfortunately it's not the right one. If I send out 6000rpm (which is 100Hz at the ATV and the lowest speed of our spindle) the ATV runs at 12,5Hz, with 9000rpm 18,7Hz etc.
I really have run out of ideas where the problem is. Maybe someone can point me in the right direction!
Thanks a lot in advance!
8 years 11 months ago #101683 by andypugh
Easy answer: Just send 8x the speed you really want :-)
It is hard to see what might be doing this at the VFD end. An easy explanation for the inverse problem would be that the motor poles setting is wrong, but it seems unlikely that it could be configured to be a 0.25 pole motor...
So, just fudge things in the code that you do have access to.
8 years 11 months ago #101696 by christian99x
Well - I had this idea already ;-) .... We had it working, that's why I actually don't want to fudge it.... but maybe that's the "easiest" solution....
Time to create page: 0.255 seconds
