PWM feedback?
- caio
13 May 2017 07:05 #93137
by caio
PWM feedback? was created by caio
hello guys,
on my cnc router i connected the spindle in closed loop configuration.
i'm using a VFD with a 0-24000 rpm spindle. linuxcnc control rpm through 0-10v signal.
for feedback i used an hall sensor than make 1 ppr.
it works quite well, but over 18k rpm the feedback isn't read properly.
so i'm thinking to use a microcontroller to convert pulses into pwm signal.
i searched a lot on internet, but i'm not sure if linuxcnc can read pwm from parallel port.
does can it do it? is there specific hal component for that?
if not, can you suggest some alternatives?
thanks
thanks
- Thank you received: 5336
13 May 2017 08:45 #93139
Replied by PCW on topic PWM feedback?
Maybe a simpler solution is just to widen the slot so the Hall pulse is longer
a 50% duty cycle pulse would optimum
- caio
13 May 2017 12:50 #93142
by caio
Replied by caio on topic PWM feedback?
Sounds strange linuxcnc can't read pwm....
anyway, to enlarge the slot (there's no slot, but a little magnet) is not so easy to do, because the sensor is integrated into the spindle, moreover i dont think a bigger duty cycle can solve the issue. my main problem is a 35k ns base thread.
but i had a new idea just now: i could build an hardware scale component to decrease the sensor pulses frequency.
do you think it might work?
- Thank you received: 7504
13 May 2017 13:28 #93143
Replied by tommylight on topic PWM feedback?
Base thread is all good, PCW is right to recomend longer pulses as it looks like whatever is sending signals to paraport has issues at higher RPM, most probably the hal sensor. A quick fix could be to add a transistor between the hal sensor and paraport with a resistor to invert the pulses.
18000 RPM is 300 pulses per second, so paraport should have no problems counting that, i can count 65000 of them per second on 2 computers i have.
- caio
13 May 2017 13:43 #93146
by caio
hi,
having a 95% duty cycle is not the same issue than 5%?
if i invert the pin in software configuration, don't i achieve the same result?
hi,
13 May 2017 16:20 #93150
Most probably but worth a try at a 20 cent cost and a bit of time.
Changing it in software is not the same thing, although you should try that. Something in that setup is causing signals from hal sensor to fall below the required treshhold for paraport.
13 May 2017 22:07 #93170
I think the issue is just duty cycle (too short of a pulse to reliably detect with a 35 usec sampling rate)
It could also be that the Hall effect sensor is not fast enough
A simple flip-flop will give you 50% duty cycle at 1/2 the speed so if the Hall
effect device is fast enough that might be a simple hardware solution
- caio
14 May 2017 13:52 #93191
by caio
i made some try with an optical sensor and an half disk on the spindle's chuck to have a perfect 50% duty cycle, but i got the same result.
so i used halscope to check signals: the feedback don't seems to have problems, also signal from hall sensor seems ok, but maybe i found the problem.
when rpm go over 18k the pwm output becomes very unstable, the spindle speed oscillate a lot and it can't go over 21k.
now i'm supposing to have a wrong software configuration, but i don't find the bottleneck.
this is my closed loop configuration, found on the wiki , with minimal changes to fit my hw.
# Closed Loop Spindle Control
# Initialize the encoder (spindle)
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
setp encoder.0.position-scale 1
setp encoder.0.counter-mode 1
# Initialize the PID
loadrt pid num_chan=1
addf pid.0.do-pid-calcs servo-thread
setp pid.0.Pgain 0
setp pid.0.Igain 1
setp pid.0.Dgain 1
setp pid.0.maxoutput 24000
# Initialize the pwmgen
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
setp pwmgen.0.pwm-freq 1000.0
setp pwmgen.0.min-dc 0.18
setp pwmgen.0.scale 24000
setp pwmgen.0.dither-pwm true
# Initialize the scale
# (This is used to scale the encoder pulse to RPM)
# (In my case, i have 1 ppr so it is scaled by 60)
loadrt scale count=1
addf scale.0 servo-thread
setp scale.0.gain 60
# Initialize the sum2
loadrt sum2 count=1
addf sum2.0 servo-thread
# Attach the motion.spindle-on to enable the pwmgen and the pid
net spindle-on motion.spindle-on => pwmgen.0.enable => pid.0.enable
# Attach the encoder to the parallel port pin
#setp parport.0.pin-10-in-invert 1
net parport_10_in parport.0.pin-10-in-not => encoder.0.phase-A => encoder.0.phase-Z
# Attach the encoder to the motion and the scale
net spindle_rev_count encoder.0.position => motion.spindle-revs
net spindle_index_enable encoder.0.index-enable <=> motion.spindle-index-enable
net encoder_raw_velocity encoder.0.velocity => scale.0.in
# Attach the pid to the scale, motion, and sum
net pid_feedback pid.0.feedback <= motion.spindle-speed-in <= scale.0.out
net pid_command pid.0.command <= motion.spindle-speed-out => sum2.0.in0
net pid_output pid.0.output => sum2.0.in1
# Attach the pwmgen to the sum and the parallel port
net pwmgen_value pwmgen.0.value <= sum2.0.out
setp parport.0.pin-01-out-invert 1
net pwmgen_out pwmgen.0.pwm => parport.0.pin-01-outPlease Log in or Create an account to join the conversation.
14 May 2017 14:05 #93192
Can you do a hal scope of pin 10 at max speed?
14 May 2017 14:11 #93193
The instability/oscillation could be a tuning issue
For a velocity loop you generally want P and I and FF0
You set FF0 first to get as accurate RPM tracking as possible
( PID control with FF0 only is open loop ) and only then do you
add P and I
add P and I
Time to create page: 0.236 seconds
