0-10v Servo Control with 7i76E
3 years 6 months ago #268909 by PCW
Replied by PCW on topic 0-10v Servo Control with 7i76E
TXen is not needed unless connected to the driver chip
Did your bitfile meet timing?
You can start/stop SSLBP with simple register operations (using mesaflash's WPO function for example)
Basically setup the DDR/AltSource registers then issue a startall/stopall
command to the SSLBP command register
3 years 6 months ago - 3 years 6 months ago #268917 by besriworld
PWM works well. I'm uploading a "readhmid "
Warning: Spoiler!
Can you upload a link ... I'm just very new to the linuxcnc world
PS:
I upload this firmware. 7i98_7i77_7i74d.bit
I am trying to read it with command $ sudo mesaflash --device 7i98 --addr 10.10.10.10 --sserial
There is no change, only one impulse comes (when I look with the oscilloscope).
SSLBP port 0:
  SSLBP Version: 1.43
  SSLBP Channels: 1
  SSLBP Baud Rate: 2500000
PS It's working fine now
Last edit: 3 years 6 months ago by besriworld.
3 years 2 months ago #276792 by besriworld
I have a problem with the setup. I am uploading the configuration.I have a servo spindle on a lathe. I want to close the feedback in linuxcnc. When changing P 0.1, the motor increases speed. Seems pid, doesn't follow feedback.
Board 7i98
File Name: my_LinuxCN...hine.ini
File Size:238 B
File Name: my_LinuxCN...hine.hal
File Size:2.31 KB
#******************* #  SPINDLE #******************* setp   pid.s.Pgain     [SPINDLE_0]P setp   pid.s.Igain     [SPINDLE_0]I setp   pid.s.Dgain     [SPINDLE_0]D setp   pid.s.bias      [SPINDLE_0]BIAS setp   pid.s.FF0       [SPINDLE_0]FF0 setp   pid.s.FF1       [SPINDLE_0]FF1 setp   pid.s.FF2       [SPINDLE_0]FF2 setp   pid.s.deadband  [SPINDLE_0]DEADBAND setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT setp   pid.s.error-previous-target true net spindle-index-enable  =>  pid.s.index-enable net spindle-enable        =>  pid.s.enable net spindle-vel-cmd-rpm     => pid.s.command net spindle-vel-fb-rpm-abs     => pid.s.feedback net spindle-output        <=  pid.s.output # ---PWM Generator signals/setup--- setp   hm2_7i98.0.pwmgen.00.output-type 1 setp   hm2_7i98.0.pwmgen.00.scale  [SPINDLE_0]OUTPUT_SCALE net spindle-output     => hm2_7i98.0.pwmgen.00.value net spindle-enable      => hm2_7i98.0.pwmgen.00.enable     # ---Encoder feedback signals/setup--- setp    hm2_7i98.0.encoder.02.counter-mode 0 setp    hm2_7i98.0.encoder.02.filter 1 setp    hm2_7i98.0.encoder.02.index-invert 0 setp    hm2_7i98.0.encoder.02.index-mask 0 setp    hm2_7i98.0.encoder.02.index-mask-invert 0 setp    hm2_7i98.0.encoder.02.scale  [SPINDLE_0]ENCODER_SCALE net spindle-revs             <=   hm2_7i98.0.encoder.02.position net spindle-vel-fb-rps-abs       <=   hm2_7i98.0.encoder.02.velocity net spindle-vel-fb-rpm-abs       <=   hm2_7i98.0.encoder.02.velocity-rpm net spindle-index-enable     <=>  hm2_7i98.0.encoder.02.index-enable # ---setup spindle control signals--- net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs net spindle-vel-cmd-rpm        <=  spindle.0.speed-out net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs net spindle-enable             <=  spindle.0.on net spindle-cw                 <=  spindle.0.forward net spindle-ccw                <=  spindle.0.reverse net spindle-brake              <=  spindle.0.brake net spindle-revs               =>  spindle.0.revs net spindle-at-speed           =>  spindle.0.at-speed net spindle-vel-fb-rps         =>  spindle.0.speed-in net spindle-index-enable      <=>  spindle.0.index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true
3 years 2 months ago #276793 by PCW
if you set P to 0 and command say 1000 RPM, what
are the values of
spindle-vel-cmd-rpm
and
3 years 2 months ago - 3 years 2 months ago #276828 by besriworld
Hi, stupid mistake. I had to change the sign/direction of the feedback. But there seems to be a problem with my board. There is noise in the analog signal. And with 1000 revolutions per minute and without a pid regulator I get spindle-vel-fb-rpm-abs 1005-1010rpm
should I filter the analog signal?
What do you think of the scheme?  I can also upload a simulation ?
In simulation it's good, but in real life it's not good :)
Maybe I should add a capacitor in parallel with the resistor R28 ?
Last edit: 3 years 2 months ago by besriworld.
3 years 2 months ago #276834 by PCW
I think the filter is not needed, also feedback is likely not needed either
as speed variations of a few % will have no significant effect on machining
or spindle synchronized motions as long as your encoder resolution is greater
than say100 PPR.
Time to create page: 0.460 seconds
