Unable to resolve coolant momentary switch issue
8 years 9 months ago #104922 by IIOII
I checked the functionality on one of my machines. As expected, when the estop is triggered, the coolant shuts off. When the estop is reset and the machine reactivated, the coolant will switch on/off normally by either using M08, the switch I have wired on my control panel or ticking the 'coolant' box.
Seems to suggest that there may be a fault somewhere else in your system.
8 years 9 months ago #104928 by OT-CNC
IIOII,
Thanks for testing it on your machine. I have attached my hal file (work in progress) in case someone has time to look at it.
8 years 9 months ago #104940 by skunkworks
II0II, can I ask why you switched from mach4?
8 years 9 months ago #105152 by IIOII
I actually switched prior to completing the build and using the machines. I made the decision mostly due to having more confidence in the stability of the Linux OS, better optimisation of system resources and less inherent bloatware. In addition I prefer the simpler user interface of Axis. I guess too, I had the choice to either buy two Mach4 licenses or for about the same cash, two Mesa cards.
A few minor things annoy me about the Linux OS which would have been very straight forward to fix in Windows. i.e. I run my screens rotated 90 degrees and the rotation only happens after the log-on screen and although both of machines run identical PCs and hardware, it's only possible to select a low screen resolution on one of the screens. Overall I'm very happy with the performance of LinuxCNC and the decision. The Linuxcnc community support is great too!
Time to create page: 0.227 seconds
