1 of 3 to output // 7i73 MPG not functioning
9 years 1 month ago - 9 years 1 month ago #98839 by tecno
Hi guys,
Tinkering of a mpg.hal file and I need some advice here.
Have 3 inputs and I want 1 output go TRUE if one of these inputs is TRUE.
How to do this? 2 XOR2's or what?
+ I want that output to be flashing also.
This is the file so far
# Jog Pendant
loadrt encoder num_chan=1
loadrt mux4 count=1
loadrt xor2 count=2
loadrt siggen num_chan=1
addf encoder.capture-position servo-thread
addf encoder.update-counters base-thread
addf mux4.0 servo-thread
addf xor2.0 servo-thread
addf siggen.0.update servo-thread
# If your MPG outputs a quadrature signal per click set x4 to 1
# If your MPG puts out 1 pulse per click set x4 to 0
setp encoder.0.x4-mode 0
# For velocity mode, set to 1
# In velocity mode the axis stops when the dial is stopped
# even if that means the commanded motion is not completed,
# For position mode (the default), set to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
setp axis.0.jog-vel-mode 1
setp axis.1.jog-vel-mode 1
setp axis.2.jog-vel-mode 1
# This sets the scale that will be used based on the input to the mux4
setp mux4.0.in0 0.1
setp mux4.0.in1 0.01
setp mux4.0.in2 0.001
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= hm2_7i76e.0.7i73.0.1.input-01
net scale2 mux4.0.sel1 <= hm2_7i76e.0.7i73.0.1.input-02
# The output from the mux4 is sent to each axis jog scale
net mpg-scale <= mux4.0.out
net mpg-scale => axis.0.jog-scale
net mpg-scale => axis.1.jog-scale
net mpg-scale => axis.2.jog-scale
# The MPG inputs
net mpg-a encoder.0.phase-A <= hm2_7i76e.0.7i73.0.1.input-08
net mpg-b encoder.0.phase-B <= hm2_7i76e.0.7i73.0.1.input-09
# The Axis select inputs
net mpg <= hm2_7i76e.0.7i73.0.1.input-03 ### This setting disables the MPG
net mpg-x axis.0.jog-enable <= hm2_7i76e.0.7i73.0.1.input-04
net mpg-y axis.1.jog-enable <= hm2_7i76e.0.7i73.0.1.input-05
net mpg-z axis.2.jog-enable <= hm2_7i76e.0.7i73.0.1.input-06
# The encoder output counts to the axis. Only the selected axis will move.
net encoder-counts <= encoder.0.counts
net encoder-counts => axis.0.jog-counts
net encoder-counts => axis.1.jog-counts
net encoder-counts => axis.2.jog-counts
# Activate MPG - ON flashing light in frontpanel
net mpglight-in1 <= hm2_7i76e.0.7i73.0.1.input-04 xor2.0.in0
net mpglight-in2 <= hm2_7i76e.0.7i73.0.1.input-05 xor2.0.in1
net next-out <= xor2.0.out
net mpglight-in3 <= hm2_7i76e.0.7i73.0.1.input-06 xor2.1.in0
net next-out xor2.1.in1
net mpglight-out <= xor2.1.out
net mpglight-out => hm2_7i76e.0.7i73.0.1.output-15
Last edit: 9 years 1 month ago by tecno. Reason: added text in subject
9 years 1 month ago - 9 years 1 month ago #98841 by PCW
Replied by PCW on topic 1 of 3 to output
It really doesn't make sense to use the software MPG component when
the 7I73 (and the 7I76E) have built in MPG counters (also you cannot use a base thread with the 7I76E)
Last edit: 9 years 1 month ago by PCW.
9 years 1 month ago #98842 by tecno
Replied by tecno on topic 1 of 3 to output
OK, can you please point me in the right direction = I am all ears.
9 years 1 month ago #98844 by PCW
did you check the available 7I73 hal pins?
9 years 1 month ago #98845 by tecno
It is setup for I/O + MPG
IN 0 to 6 for x1 x10 x100 and MPG off X Y Z
IN 8 and 9 A / B
Out 15 for indicator light MPG active
Following is in HAL but does not work so something missing?
### MPG increment selector
# --- JOG-INCR-A ---
net jog-incr-a <= hm2_7i76e.0.7i73.0.1.input-00
# --- JOG-INCR-B ---
net jog-incr-b <= hm2_7i76e.0.7i73.0.1.input-01
# --- JOG-INCR-C ---
net jog-incr-c <= hm2_7i76e.0.7i73.0.1.input-02
### MPG axis selector
# --- JOINT-SELECT-A ---
net joint-select-a <= hm2_7i76e.0.7i73.0.1.input-04
# --- JOINT-SELECT-B ---
net joint-select-b <= hm2_7i76e.0.7i73.0.1.input-05
# --- JOINT-SELECT-C ---
net joint-select-c <= hm2_7i76e.0.7i73.0.1.input-06
# ---jogwheel signals to mesa encoder - shared MPG---
net joint-selected-count <= hm2_7i76e.0.7i73.0.1.enc1.count
# ---mpg signals---
# for axis x MPG
setp axis.0.jog-vel-mode 0
net selected-jog-incr => axis.0.jog-scale
net joint-select-a => axis.0.jog-enable
net joint-selected-count => axis.0.jog-counts
# for axis y MPG
setp axis.1.jog-vel-mode 0
net selected-jog-incr => axis.1.jog-scale
net joint-select-b => axis.1.jog-enable
net joint-selected-count => axis.1.jog-counts
# for axis z MPG
setp axis.2.jog-vel-mode 0
net selected-jog-incr => axis.2.jog-scale
net joint-select-c => axis.2.jog-enable
net joint-selected-count => axis.2.jog-counts
# for axis a MPG
setp axis.3.jog-vel-mode 0
net selected-jog-incr => axis.3.jog-scale
net joint-select-d => axis.3.jog-enable
net joint-selected-count => axis.3.jog-counts
sets selected-jog-incr 0.000000
9 years 1 month ago #98860 by rodw
Replied by rodw on topic 1 of 3 to output
There are a couple of examples of using MPG's with the 7i76e in my Spaceship plasma build thread. You have my Hal file anyway.
It uses binary coded selectors to save on output pins.
Time to create page: 0.377 seconds
