axis.5.motor-pos-cmd = -nan
8 years 11 months ago #101396 by Henk
Replied by Henk on topic axis.5.motor-pos-cmd = -nan
No, it s a standard C-axis config. command comes from motion.
axis.5.motor-pos-cmd => pid => 7i77 analog-out...
C-axis movement is achieved by fiddling with the feedback signal in gearhob.comp.
Henk
8 years 11 months ago #101398 by Henk
#ing out the addf line for gearhob.comp doesn't solve the issue as suspected.
thanks
Henk
8 years 11 months ago #101400 by andypugh
Henk wrote: No, it s a standard C-axis config. command comes from motion.
OK, and that output only goes to the PID, I assume? (This doesn't matter for investigating this problem, I am just curious about whether your way is better than my way as I do a fair bit of gear hobbing myself).
When does the NaN appear? I wonder if Halscope would be able to track it propogating through the system.
8 years 11 months ago #101401 by Henk
As soon as the gui loads, I check this in Hal configuration and it shows nan. this is before the e-stop is released on the gui and the machine still off. it seems as if it starts up that way.
Henk
8 years 11 months ago #101404 by andypugh
As my next step I would comment-out everything related to the axis in HAL and see if the problem still occurs.
You can then run the HAL commands one-by-one in an interactive HAL session (halcmd -kf after LinuxCNC loads) to see if you can work out where the problem starts.
Are you using Trivkins?
8 years 11 months ago #101408 by Henk
Hi Andy
Yes, I'm using trivkins.
Ill try that, thanks
Henk
Time to create page: 0.342 seconds
