how to pause program through input pin?
8 years 7 months ago - 8 years 7 months ago #107202 by Grotius
net pause hauli.program.pause parport.0.pin-12-in net pause hauli.program.pause parport.0.pin-12-in-not
This will end in a tiny bug. Explenation required :
You can not use your "pause" in different configuration's
It has one explenation : or pin 12 high, or pin 12 low. High and low at the same time is not possible, unless you
are expecting an electrical failure.
net pause hauli.program.pause parport.0.pin-12-in net pause-not hauli.program.pause parport.0.pin-12-in-not
Will end in a tiny succes without bug. In this way you have a "net pause" and a "net pause-not"
It separates the high and low value. Next item for you is to use this names in your program code.
Last edit: 8 years 7 months ago by Grotius.
The following user(s) said Thank You: davidcnc
