- Thank you received: 11
cmorley wrote: On a side note looks like you used PNCconf for your initial configuration - how well did that work for the VFD ?
It's an option that I can't test well as I don't have that VFD.
BigJohnT wrote: I have a GS2 on my BP with encoder feedback on the spindle.
This is my HAL for the spindle:Code:# Spindle Drive loadusr -Wn spindle-vfd gs2_vfd -s 2 -p none -A 0.5 -D 0.5 -R -n spindle-vfd -v # connect the spindle direction pin to the GS2 net gs2-fwd spindle-vfd.spindle-fwd <= motion.spindle-forward # connect the spindle on pin to the GS2 net gs2-run spindle-vfd.spindle-on <= motion.spindle-on # connect the GS2 at speed to the motion at speed net gs2-at-speed motion.spindle-at-speed <= spindle-vfd.at-speed # connect the spindle RPM to the GS2 net gs2-RPM spindle-vfd.speed-command <= motion.spindle-speed-out #vfd panel fan net gs2-run => hm2_5i25.0.7i77.0.0.output-03 # Spindle Encoder setp hm2_5i25.0.encoder.03.scale 10000 net spindle-position hm2_5i25.0.encoder.03.position => motion.spindle-revs net spindle-velocity hm2_5i25.0.encoder.03.velocity => motion.spindle-speed-in net spindle-index-enable hm2_5i25.0.encoder.03.index-enable <=> motion.spindle-index-enable
JT
