Spindle at speed using CSS and G33 (Spindle controlled with VFD)
8 years 9 months ago #105254 by tome
We have an Emco lathe with a Automation Direct GS2 VFD driving the motor. We have an encoder on the spindle. The machine is running Linuxcnc 2.7.11.
We have CSS on and are threading with a G33 on our Emco lathe and we are seeing the spindle decelerating during the cut. Seems like the spindle speed should be fairly steady at a given X location during a G33. What I think is happening is that the spindle is still decelerating to speed while it’s in the cut rather than before entering the cut.
We are rapid-ing (G0 in Z) out of the part at the center of the part (X=0) and so CSS spins the spindle up to full speed as I’d expect but it appears that our spindle is still decelerating to speed as the next threading pass is happening. We read that G33 will wait for spindle-at-speed before looking for the index pulse. But our spindle-at-speed signal seems to be high during the full cycle once the spindle speeds up the first time. It seems like spindle-at-speed should go low after rapiding out of the part as it moves to it’s next X location and decelerates to it’s next speed at the cutting diameter. Or are we misunderstanding spindle-at-speed when CSS is in effect?
In our configuration the hal pin motion.spindle-at-speed is set by the VFD (according to the examples for using the GS2 VFD):
# load the user space component for the Automation Direct GS2 VFD's loadusr -Wn spindle-vfd gs2_vfd -r 9600 -p none -s 2 -n spindle-vfd -A 1 -D 2.0 -X # connect the spindle direction pin to the GS2 net gs2-fwd spindle-vfd.spindle-fwd <= motion.spindle-forward # connect the spindle on pin to the GS2 net gs2-run spindle-vfd.spindle-on <= motion.spindle-on # connect the GS2 at speed to the motion at speed net gs2-at-speed motion.spindle-at-speed <= spindle-vfd.at-speed # connect the spindle RPM to the GS2 # scale pulley ratio on spindle (1/0.833133) setp scale.1.gain 1.154 net commanded-speed scale.1.in motion.spindle-speed-out net gs2-RPM spindle-vfd.speed-command scale.1.out
The only other spindle related config in my .hal file is:
#******************* # SPINDLE S #******************* # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.00.counter-mode 1 #setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= hm2_5i25.0.encoder.00.position => motion.spindle-revs net spindle-vel-fb-rps <= hm2_5i25.0.encoder.00.velocity => motion.spindle-speed-in net spindle-index-enable <=> hm2_5i25.0.encoder.00.index-enable <=> motion.spindle-index-enable net spindle-index <= hm2_5i25.0.encoder.00.input-index
But sections 6.1 and 6.2 of this manual: linuxcnc.org/docs/html/examples/spindle.html
Show the spindle velocity (as determined by the encoder) and the commanded velocity compared though a "near" component to determine the state of motion.spindle-at-speed.
What is the right way, when using the VFD to still ensure that the spindle is really at speed before cutting?
Thanks,
-Tom
8 years 9 months ago #105264 by cmorley
If you are using the VFD's spindle-at-speed then you must adjust the VFD it's self to adjust the behavior.
I am not sure the options available on your VFD.
You can use linuxcnc to calculate spindle-at-speed using encoder feedback (if available) and the near component.
In linuxcnc's motion controller case it doesn't care how it's done - if spindle-at-speed is false at the beginning of a feed move if will wait.
On a side note looks like you used PNCconf for your initial configuration - how well did that work for the VFD ?
It's an option that I can't test well as I don't have that VFD.
Chris M
Chris M
8 years 9 months ago #105279 by BigJohnT
I have a GS2 on my BP with encoder feedback on the spindle.
This is my HAL for the spindle:
# Spindle Drive loadusr -Wn spindle-vfd gs2_vfd -s 2 -p none -A 0.5 -D 0.5 -R -n spindle-vfd -v # connect the spindle direction pin to the GS2 net gs2-fwd spindle-vfd.spindle-fwd <= motion.spindle-forward # connect the spindle on pin to the GS2 net gs2-run spindle-vfd.spindle-on <= motion.spindle-on # connect the GS2 at speed to the motion at speed net gs2-at-speed motion.spindle-at-speed <= spindle-vfd.at-speed # connect the spindle RPM to the GS2 net gs2-RPM spindle-vfd.speed-command <= motion.spindle-speed-out #vfd panel fan net gs2-run => hm2_5i25.0.7i77.0.0.output-03 # Spindle Encoder setp hm2_5i25.0.encoder.03.scale 10000 net spindle-position hm2_5i25.0.encoder.03.position => motion.spindle-revs net spindle-velocity hm2_5i25.0.encoder.03.velocity => motion.spindle-speed-in net spindle-index-enable hm2_5i25.0.encoder.03.index-enable <=> motion.spindle-index-enable
JT
8 years 9 months ago #105295 by tome
cmorley wrote: On a side note looks like you used PNCconf for your initial configuration - how well did that work for the VFD ?
Thanks for the reply Chris. It has been a couple years now since I made the config for the lathe. I can't recall if PNCconf did the right thing with the VFD. I want to say I found the configuration for that separately on the Linuxcnc wiki but I could be mistaken.
-Tom
8 years 9 months ago #105298 by tome
BigJohnT wrote: I have a GS2 on my BP with encoder feedback on the spindle.
JT
JT,
Thanks for the reply. So, our two configs are essentially identical as far as I can see. Do you do threading, tapping, or other synchronized motion on your machine and if so, does it work reliably for you?
I do wonder if using the spindle encoder is a better method of tracking spindle-at-speed rather than relying on the VFD to say it is at commanded speed? There are pulleys and a belt that connect the motor to the spindle on my lathe whereas the encoder is directly connected to the spindle...
8 years 8 months ago #105300 by BigJohnT
Yes I do rigid tapping with the BP often and never a glitch. Threading is not possible on a mill but I do threading on my CHNC with encoder feedback on the spindle. It's a servo drive not a VFD.
JT
Time to create page: 0.377 seconds
