andypugh wrote: This almost looks like the module has forgotten how to handle the "device=" parameter
(It acts puzzled, and then falls-back to the default)
The "unhandled argument" is not due to permissions, that would be a different error.
What is the exact loadusr line for the component?
andypugh wrote: Yes, but, does it actually work?
It sounds like it is connecting to ttyS0 and that won't raise any errors, but probably is not going to work.
It is possible that the device has been re-assigned to a different ttyUSB. (Though that, too, would cause a different error).
This might help:
unix.stackexchange.com/questions/66901/h...-under-a-static-name
KERNELS=="1-3", SUBSYSTEMS=="usb", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", SYMLINK+="ttyS0", MODE="0660"
