v2.8.0 - Pin 'motion.spindle-forward' does not exist
10 Oct 2018 00:43 - 10 Oct 2018 00:45 #118620 by deemoss
Hi guys,
I am trying to control the spindle with rs485 according to these instructions buildyourcnc.com/FAQ/13271.
However, as I run LinuxCNC I get the error "./custom.hal:10: Pin 'motion.spindle-forward' does not exist". Also, when I execute the halcmd in terminal I get the same error.
Why is this?
I am using 2.8.0 pre 1
The error log is attached.
Thanks!
Last edit: 10 Oct 2018 00:45 by deemoss.
10 Oct 2018 01:31 #118623 by racedirector
Replied by racedirector on topic v2.8.0 - Pin 'motion.spindle-forward' does not exist
Ran across the same thing, motion has changed for 2.8
You will need to change all spindle references to spindle.xxx
spindle.forward should fix your particular issue.
Cheers
10 Oct 2018 02:38 #118627 by deemoss
Thanks racedirector,
I tried the below with no luck. Also should't I see a "spindle" component in the halshow (see screenshot)?
net spindle-cw spindle.0.forward => vfd.spindle-forward
> Pin 'spindle.0.forward' does not exist
and
net spindle-cw halui.spindle.0.forward => vfd.spindle-forward
> Pin 'halui.spindle.0.forward' does not exist
Thanks!
10 Oct 2018 02:44 #118628 by racedirector
spindle is actually part of motion, take a look at motion in the 2.8 docs, thats how I found it.
10 Oct 2018 02:46 #118629 by racedirector
10 Oct 2018 04:41 #118630 by deemoss
Still no joy
dimos@lcnc ~ $ halrun
halcmd: loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB0 -p none -r 9600
halcmd: net spindle-cmd-rpm-abs => vfd.speed-command
halcmd: net spindle-cw motion.spindle.0.forward => vfd.spindle-forward
<stdin>:3: Pin 'motion.spindle.0.forward' does not exist
10 Oct 2018 05:04 #118631 by deemoss
OK it worked when I run lcnc, with the changes applied to custom.hal. Why it didn't work in terminal with halcmd?
10 Oct 2018 05:31 - 10 Oct 2018 05:32 #118633 by racedirector
I would say because you were still using "motion." "spindle.0.xxx" doesn't use "motion." first.
if you took the "motion." part off this command it would probably work :)
Last edit: 10 Oct 2018 05:32 by racedirector.
The following user(s) said Thank You: deemoss
10 Oct 2018 08:37 #118640 by PCW
You also did not load motion (emcmot)
(you only loaded the VFD module so only VFD pins are available)
AFAIK spindle is still part of motion regardless of any name changes
The following user(s) said Thank You: racedirector, deemoss
11 Oct 2018 02:47 #118664 by deemoss
Thanks racedirector!
Time to create page: 0.186 seconds
