HAL names - 16 argument limit?
7 years 9 months ago #124823 by mjohnston
Hi all,
I've run into an issue with my HAL files for a project I'm working on. When using "loadrt and2 names=", it seems that listing more than 16 names causes the insmod call to fail, resulting in none of those HAL components being created. I don't think this is specific to and2, but maybe it is. See below for a command line printout showing the error. I'm assuming the 16 argument limit is hard-coded somewhere, but is there any way around it?
Some background: for what I'm trying to do, using names instead of count is necessary. I'm trying to split out some basic logic and timers into a separate HAL file, which requires using twopass to load all the components common to both files (like and2). I don't want to have to rewrite an entire file if the number of and2's (or any shared component) in the first file changes. I have been using classicladder for this logic up until now, but I wanted to move it to HAL to simplify things a bit - one less 'program' to maintain, and it's a little cumbersome that you need an operational LinuxCNC instance running in order to edit the ladder.
names=and2.0,and2.1,and2.2,and2.3,and2.4,and2.5,and2.6,and2.7,and2.8,and2.9,and2.10,and2.11,and2.12,and2.x1.fault,and2.x2.fault,and2.y.fault,and2.z.fault,and2.c.fault,and2.s1.fault.0,and2.s1.fault.1,and2.fault,and2.es.act,and2.es.reset,and2.s1.act,and2.s2.act,and2.s.on,and2.s.noton,and2.ll.on,and2.ll.off: can only take 16 arguments twopass: load_the_modules cmd=<orig_loadrt and2 names=and2.0,and2.1,and2.2,and2.3,and2.4,and2.5,and2.6,and2.7,and2.8,and2.9,and2.10,and2.11,and2.12,and2.x1.fault,and2.x2.fault,and2.y.fault,and2.z.fault,and2.c.fault,and2.s1.fault.0,and2.s1.fault.1,and2.fault,and2.es.act,and2.es.reset,and2.s1.act,and2.s2.act,and2.s.on,and2.s.noton,and2.ll.on,and2.ll.off> waitpid failed /usr/bin/rtapi_app and2 /usr/bin/rtapi_app exited without becoming ready insmod for and2 failed, returned -1 creating ladder-state HAL: ERROR: function 'and2.0' not found twopass: Error in file ./customspray.hal: addf failed
7 years 9 months ago - 7 years 9 months ago #124845 by dgarrett
insmod call to fail
The limit of 16 for names= instances is set by halcompile.
The 16 value is hardcoded in a number of places in halcompile.g:
github.com/LinuxCNC/linuxcnc/blob/master...l/utils/halcompile.g
Some possible solutions for a RIP build:
1) handedit the 16 value in appropriate places in halcompile.g, then rebuild
2) to make a little easier, i've made a branch that
parameterizes the number of names= instances so you just edit in
one place (MAX_NAMES=)
(this branch could likely be merged to master if sufficiently tested)
Ref: github.com/LinuxCNC/linuxcnc/commits/dgarr/halcompile_max_names
Commit: github.com/LinuxCNC/linuxcnc/commit/0eb1...8256f79de07c0a5f2b26
For a deb install, you could build some additional
components using halcompile that replicate the and2.comp
with different file/component names:
cp and2.comp myand2.comp edit myand2.comp to make the component name myand2 (the component name inside the .comp file should agree with the file name) sudo halcompile --install myand2.comp
you then can use 16 name= instances of and2
and 16 name= instances of myand2
Last edit: 7 years 9 months ago by dgarrett.
The following user(s) said Thank You: Mike_Eitel, mjohnston
7 years 9 months ago #124856 by Mike_Eitel
Now I understand.
I run recently into the same with two many and2. Solved it by inverted logic, but it looks odd.
Is that restriction somewhere in the docs.
THX
7 years 9 months ago - 7 years 9 months ago #124857 by mjohnston
dgarret, thanks for the answer! I suspected it was something like that, but it's good to know for sure. :) I would say that change should be pulled (magic numbers are bad!), but that's not up to me. Now I just need to decide which way I want to solve it in the mean time...
Mike, I didn't find mention of the 16 instance limit in the docs, but I also skimmed a lot.
Looking at halcompile.g, it looks like the same limit will apply to any HAL component that uses a personality (e.g. logic or lut5).Is there any hidden downside to increasing the max number of named instances? The fact that you can exceed that limit by using count= suggests to me that there isn't, someone just had to pick a number at some point in the past.
Edit: It's true that having more than 16 names and personalities on one line of a HAL file would be very cumbersome to read. However, that can be mitigated by splitting it into multiple loadrt lines and turning TWOPASS = on in the ini file, so that isn't a real limitation IMO.
Last edit: 7 years 9 months ago by mjohnston.
7 years 9 months ago #124858 by Mike_Eitel
I'm using always names, multiple hal and twopass.
Doesn't matter in with file.
It did not work.
Mike
7 years 9 months ago #125086 by mjohnston
Sorry, Mike, I guess I could've formatted my post a bit better. My last two paragraphs were meant to be just a discussion of the source code, not a solution to the issue.
As far as I can see, the only solutions for now are what dgarrett mentioned in his post.
Time to create page: 0.278 seconds
