star-traveler wrote:
1 - Is that a good idea at all? (Is there something like that already?)
2 - Does the architecture of LinuxCNC have a clear separation between the working thread that controls the motors and the GUI thread? I suppose there is, and the two communicate via command and data queues?! "The GUI thread sends commands to the worker thread and the worker thread sends back the current position of the tool."?!...
3 - In your opinion (as someone who's familiar with the code). Is the job of separating the two trivial, or would require writing/re-writing a lot of code?
4 - In your opinion, do you think there's going to be a lot of lag between back-end and front-end due to the LAN interface connecting them?
Now is a good time to ask, why dose LinuxCNC still ship on a 32-bit OS? I feel like it's a waste of hardware resources.
If you want an easy way to run the hardware and GUI on different hardware then you should probably look at Machinekit, which seems to specialise in running the realtime on a Beaglebone with a remote GUI.
Do you think the same can be achieved through modifying the LinuxCNC's source code itself, so that front-end and back-end are internally separated and communicate through some sort of custom protocol?
Maybe as Andypugh suggested, the machinekit may offer a more ready solution. I believe it forked from a common code and should be quite compatible a few revisions ago. I do not have any idea of how it works, but I imagine having hal communicating over lan would be a way to glue it to everything, with it's own drawbacks.
