Thank you very much! That seems like a way I'd like to configure it.
But..... how about support? The last used versions of LCNC in this project is rather old. And I have only looked at it briefly now and I must say I wonder if this will give me other problems.
First off, I'm sure I need support here. And the only way to get that is to post config files. And I expect good old text-based files are the norm, and also how others would be able to read them too.
So the question is if the config files made by this system is readable. And also if they are compatible with 2.8 and 2.9, with differences in axis/joints. I will have to insist on using these versions as they have features I need.
But I have to admit it's a good idea, if it would be easy to use, and not add another layer of things we have to learn how to use.... there are enough of them already.
And..... Eagle is bought up by Autodesk now. And I don't have a student login. So I guess earlier versions might be a solution here. This is another layer of complication with this approach…..
I will look some more in to this to figure out if this is a way to do it that suits me. And at the same time is easy for others to help me and read my config files.
For now I have tried to make my HAL files look tidy, with consistent ways to write names and having everything that belongs on the same line, and signal going from left to right and such. I expect Eagle-HAL to not be able to do this, and to be more like PNCconf and how config tools like it make configs (I fully understand why it’s like that with those tools! It would be close to impossible to make this happen in a consistent way in a complicated tool like that).
