andypugh’s nice HAL schematic
  • JC10
  • Topic Author
  • Senior Member
  • Senior Member
6 years 10 months ago - 6 years 10 months ago #153000 by JC10
andypugh’s nice HAL schematic was created by JC10
Hello,
question for andypugh : what software do you use to produce the nice schematic in the svg file of wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient ?
Last edit: 6 years 10 months ago by JC10.
6 years 10 months ago #153141 by andypugh
Replied by andypugh on topic andypugh’s nice HAL schematic
I used Excel. :-/
The following user(s) said Thank You: JC10
6 years 10 months ago #153252 by akb1212
Replied by akb1212 on topic andypugh’s nice HAL schematic
I also wondered about that....
Turns out that is only available in the cloud based (and therefore to me totally unacceptable (I have a paid licence for earlier "proper" version, and absolutely don't like the new "upgrades", and the fact that I have to pay them more for every month I use it)) office 365. Bummer!
I really wanted to share my updated schematic I made, first to update it to include new pins in 2.8 and to get your feedback on if my additions are correct.
And then to help others in the future.
And I do find a good schematic so much easier to work with than text-based files. At least when it comes to signal flow and trace the different signal paths (and I am an electronics engineer, and have grown up with reading schematics.....).
I will have to look in to if it's possible to use open office.
I have to say I do miss Visio now.....
  • JC10
  • Topic Author
  • Senior Member
  • Senior Member
6 years 10 months ago - 6 years 10 months ago #153254 by JC10
Replied by JC10 on topic andypugh’s nice HAL schematic
Open office should do the trick.
I use google sheets that is not as good as Excel but you can work on your sheets from any device, I found this handy.
You are electronics engineer, have a look at this : wiki.linuxcnc.org/cgi-bin/wiki.pl?Eagle2HAL
And : softsolder.com/2013/02/28/eagle-6-4-sche...-creation-checklist/
and all very good related posts from this guy.
6 years 10 months ago #153298 by akb1212
Thank you very much! That seems like a way I'd like to configure it.
But..... how about support? The last used versions of LCNC in this project is rather old. And I have only looked at it briefly now and I must say I wonder if this will give me other problems.
First off, I'm sure I need support here. And the only way to get that is to post config files. And I expect good old text-based files are the norm, and also how others would be able to read them too.
So the question is if the config files made by this system is readable. And also if they are compatible with 2.8 and 2.9, with differences in axis/joints. I will have to insist on using these versions as they have features I need.
But I have to admit it's a good idea, if it would be easy to use, and not add another layer of things we have to learn how to use.... there are enough of them already.
And..... Eagle is bought up by Autodesk now. And I don't have a student login. So I guess earlier versions might be a solution here. This is another layer of complication with this approach…..
I will look some more in to this to figure out if this is a way to do it that suits me. And at the same time is easy for others to help me and read my config files.
For now I have tried to make my HAL files look tidy, with consistent ways to write names and having everything that belongs on the same line, and signal going from left to right and such. I expect Eagle-HAL to not be able to do this, and to be more like PNCconf and how config tools like it make configs (I fully understand why it’s like that with those tools! It would be close to impossible to make this happen in a consistent way in a complicated tool like that).
6 years 10 months ago #153328 by andypugh
The following user(s) said Thank You: akb1212, JC10
7 months 2 weeks ago #344551 by andypugh
I re-found this post looking for something else.
If I was drawing the schematic again today, I would probably use Miro.
That is cloud-based too, but it is basically for drawing such diagrams.
miro.com/
7 months 2 weeks ago #344554 by andrax
Replied by andrax on topic andypugh’s nice HAL schematic
If you're just looking for a schematic, you should take a closer look at KiCad.
7 months 2 weeks ago - 7 months 2 weeks ago #344561 by NWE
Replied by NWE on topic andypugh’s nice HAL schematic
Don't know whether this would be a solution for your use case or not, I have been doing this in libreoffice draw. Sometimes I get to crowding the pages a bit, but if I'm not planning on printing to paper it is easy enough to set the page size larger.
Each hal component pin is an individual rectangle. The signal wires are 'connectors' so they readily stick to the rectangles and come with when I pull rectangles around. For the signal names I've just been pasting smaller rectangles on top of the connector lines. They're not attached and easily get lost if I start rearranging stuff. Next time I'm drawing one of these I want to use two connector lines to one signal like:
[hal pin a]  -  -  -  [signal name]  -  -  -  >[hal pin b]
(still in libreoffice draw) the first connector will be drawn from "hal pin a" to the signal name rectangle. The second one will be from signal name to "hal pin b"
With the rectangles I do a lot of copy/paste. I don't drag them around much with the mouse, rather select and move in increments with the arrow keys or enter calculated positions.
I frequently work with the page display zoomed in some when doing this, makes it easier to grab the handles.
I see andypugh has his input/output pins left vs right justified, that is a new idea for me, I'll start doing that way as well. I had all my text center justified.
Last edit: 7 months 2 weeks ago by NWE.
Time to create page: 0.106 seconds
