Hi
I know I have successfully done this before but now cannot for the life of me figure out what I am doing wrong!
I want to modify a kinematics module, and as a start simply renamed 5axiskins.c to 5axiskins2.c. Then I did
halcompile --install 5axiskins2.c
from the directory containing it, and received a confirmatory message that the 5axiskins2.so had been added to the usual library, which I checked it had.
However when I add it to the ini as the [KINS] module, simply adding a 2 to the 5axiskins already there, linuxcnc starts up but gets stuck in a "waiting for component" loop for the 5axiskins2 module.
Any clues as to my mistake?
Cheers!
