ShuttleXpress pins not fond after updating to 2.9.0-pre0-2180-ga14b08a70
  • JetForMe
  • JetForMe's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Jun 2020 09:18 #171099 by JetForMe
Prior to this I had 2.9.0 7xx-something. The ShuttleXpress was found and installed just fine. Now it finds it, but it doesn't seem to create the pins for it.:
Found file(REL): ./custom.hal
shuttle: checking /dev/hidraw0
shuttle: found Contour Design ShuttleXpress on /dev/hidraw0
shuttle: checking /dev/hidraw1
shuttle: error opening /dev/hidraw1: Permission denied
shuttle: make sure you have read permission on /dev/hidraw1, read the shuttle(1) manpage for more info
shuttle: checking /dev/hidraw2
shuttle: error opening /dev/hidraw2: Permission denied
shuttle: make sure you have read permission on /dev/hidraw2, read the shuttle(1) manpage for more info
shuttle: checking /dev/hidraw3
shuttle: error opening /dev/hidraw3: Permission denied
shuttle: make sure you have read permission on /dev/hidraw3, read the shuttle(1) manpage for more info
./custom.hal:19: Pin 'shuttlexpress.button-0' does not exist
My HAL:
#	Contour ShuttleXpress
loadusr -W shuttle
LINE 19: net select-axis-x		halui.joint.0.select									<=	shuttlexpress.0.button-0
net select-axis-y		halui.joint.1.select									<=	shuttlexpress.0.button-1
net select-axis-z		halui.joint.3.select									<=	shuttlexpress.0.button-2
net sxp.continuous														<=	shuttlexpress.0.spring-wheel-s32
Is there a way to get LinuxCNC to log the pins as it creates them?
11 Jun 2020 09:44 #171103 by rodw
My guess is you need to change permissions as mentioned in the error message. Because you cannot open files and/or devices, the relevant pins cannot exist. It should be a simple fix.
  • Moderator
  • Moderator
11 Jun 2020 11:34 #171123 by tommylight
Search for arduino permission denied, the the user has to be added to dialout group to be able to access it.
11 Jun 2020 12:17 - 11 Jun 2020 12:42 #171124 by dgarrett
linuxcnc.org/docs/2.8/html/getting-start...med_to_tt_shuttle_tt
github.com/LinuxCNC/linuxcnc/commit/ba077f564
edit: rereading, you have correct loadusr line so the messages about
permission are most relevant, maybe this helps:
linuxcnc.org/docs/master/html/drivers/shuttle.html
Last edit: 11 Jun 2020 12:42 by dgarrett.
11 Jun 2020 13:02 #171130 by bbsr_5a
you also need to be member of the Dialout group to get this pins viewed in Hal
sudo usermod -a -G dialout $USER
  • JetForMe
  • Elite Member
  • Elite Member
11 Jun 2020 23:26 #171188 by JetForMe
I do have it configured as shown in the man page. If you look you can see it found the ShuttleXpress on /dev/hidraw0. That one is world-readable. The other three devices are the keyboard and mouse and one other thing I can't remember. Those are owned by the system and only root-readable. Not sure why it would need to find those.
Unless I misinterpreted what I saw, in which case all I can say is I *do* have the udev stuff configured as specified in the man page, so I'm not sure why it's not changing the rest of it to readable.
Note that this worked before I updated to the latest build, and I haven't changed any configuration. I also updated from Stretch 9.11 to 9.12.
  • JetForMe
  • Elite Member
  • Elite Member
11 Jun 2020 23:27 #171189 by JetForMe
Sorry, missed the other replies. Let me try that again. Not sure why it broke, though.
  • JetForMe
  • Elite Member
  • Elite Member
14 Jun 2020 11:24 #171590 by JetForMe
Yeah, so it has proper permissions. The problem seems to be that the name changed to "shuttle", not "shuttlexpress" or "shuttlepro". I thought I tried "shuttle" earlier (it was the first thing I did), but I must've typed it wrong.
Time to create page: 1.348 seconds
