Limit switches triggered on machine off
6 years 4 months ago - 6 years 4 months ago #171502 by cmorley
Another question: in my machine (a 3d printer) i configured the vertical axis as W to obtain better smoothness during printing, but this way I can't jog the vertical axis using the keyboard anymore. Do you have a hint to find what part of the source of axis/gmoccapy I should edit to change the key bindings, so that I can move the W axis usig page up /down?
If using AXIS I think you could use the .axisrc option to redirect keybinding.
These seem to set the bindings for jogging:
bind_axis("Left", "Right", 0)
bind_axis("Down", "Up", 1)
bind_axis("Next", "Prior", 2)
bind_axis("KP_Left", "KP_Right", 0)
bind_axis("KP_Down", "KP_Up", 1)
bind_axis("KP_Next", "KP_Prior", 2)
bind_axis("KP_4", "KP_6", 0)
bind_axis("KP_2", "KP_8", 1)
bind_axis("KP_3", "KP_9", 2)
bind_axis("bracketleft", "bracketright", 3)
The number represents the axis 012345678 = XYZABCUVW
So maybe
bind_axis("Next", "Prior", 8)
bind_axis("KP_Next", "KP_Prior",,8)
bind_axis("KP_3", "KP_9", 8)
Last edit: 6 years 4 months ago by cmorley.
6 years 4 months ago #171507 by Muz94
Great, i'll try that tomorrow.
I actually used gmoccapy on the machine, but I switched to axis recently as it seems more stable and light ( but lacks the industrial look of gmoccapy) .
I want to fix the jog issue because I already crashed the machine once as the interface got stuck during jogging from the gui, and i'd like to avoid that :s
6 years 4 months ago #171648 by Muz94
I managed to solve the main problem using AND2 and timedelay components.
Using axisrc with those commands instead didn't make a difference for the key bindings.
Time to create page: 0.286 seconds
