- Thank you received: 23
Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
- B.Reilly01
- Topic Author
6 years 4 months ago #172826
by B.Reilly01
Suddenly my config doesn't work - configured in PnCConf, but error showing HAL was created by B.Reilly01
So I've been running a config configured in pncconf for a while. Recently it stopped working, and the error I'm getting is at load. Axis will not load the error is:
Debug file information:
./Hurco_SM1_052520-new_motor.hal:37: Pin 'hm2_5i25.0.7i77.0.0.output-13' does not exist
3599
Stopping realtime threads
Unloading hal components
I thought this might be a HAL problem. Output 13 is spindle CCW... I don't know much about HAL, but if I can get any help, it would be appreciated. Thank you.
3599
- Clive S
- Thank you received: 269
6 years 4 months ago #172840
by Clive S
it is always a good idea to post the hal and ini files from your "machine name" in the config folder
Replied by Clive S on topic Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
3599
6 years 4 months ago #172848
Replied by tommylight on topic Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
There is no field power going to the 7i77.B.Reilly01 wrote: Debug file information:
3599
- B.Reilly01
- Topic Author
6 years 4 months ago #172883
by B.Reilly01
Replied by B.Reilly01 on topic Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
Thank you, it was field power. I had been having problems with the 5i25 dropping out mid operation and had taken the PC out to clean the contacts and forgot to plug in the field power connector.
Time to create page: 0.043 seconds
