Teensy 4.1 + LinuxCNC
6 years 1 month ago #183346 by Roiki
Replied by Roiki on topic Teensy 4.1 + LinuxCNC
As a side note. The teensy only supports 4 encoders with A+B. Due to internal crossbaring it drops to 3 for ABZ encoders. It also works on specific pins.
Read more here: github.com/mjs513/Teensy-4.x-Quad-Encoder-Library
6 years 1 month ago #183424 by jakap
Replied by jakap on topic Teensy 4.1 + LinuxCNC
Good point. I only implemented AB encoders, as I don“t need index signals.
6 years 1 month ago #183512 by Roiki
You could also test its performance over a simple ethernet switch. Its not really recommended but mesa cards can work over them so that would be a nice feature to have in this. The latency certainly has some headroom for it.
6 years 1 month ago #183520 by tommylight
Replied by tommylight on topic Teensy 4.1 + LinuxCNC
Roiki wrote: Its not really recommended but mesa cards can work over them so that would be a nice feature to have in this.
That is never to be used on an actual machine. I did use a switch (a very fast one) and it can work for testing only.
Whenever that switch gets a bit of work load, it will end up loosing the connection to Mesa card.
So as a general rule : Never use a switch or hub between the PC and the Mesa Card.
5 years 10 months ago - 5 years 10 months ago #192512 by Markyd
Replied by Markyd on topic Teensy 4.1 + LinuxCNC
any new on how this is progressing?
I bought one of Teensy 4.1 grblHAL breakout board back in the summer and I'm keen to know if I'll be able to repurpose it to use with linuxcnc.
Last edit: 5 years 10 months ago by Markyd.
5 years 10 months ago - 5 years 10 months ago #192516 by jakap
Thanks for expressing the interest.
I know Phil's board - it is a good layout.
As my code is relying on hardware and I would like to keep the possibilities to read encoders for closed loop control, I don't think my implementation will be pin compatible to Phil's board, but I have to check this in detail in the upcoming weeks.
Anyhow, I plan to design my own board once the pinout is fixed.
At the moment, I am still working on the module for stepper motor.
To avoid interrupts and to keep down the latency I would like to count steps in an efficient way with hardware counters, but I still have some difficulties. I hope this will be ready by Christmas.
In future, I am looking forward to use distributed clock using PTP protocol. Any expert on the topic around here?
Last edit: 5 years 10 months ago by jakap.
The following user(s) said Thank You: Markyd
Time to create page: 0.157 seconds
