Modbus TCP issue with pokeys57E
6 years 4 days ago - 6 years 4 days ago #187534 by Varang1an
yes sorry for this confusion as documents made me mistake on pins and as a relatively new user of linuxcnc (have two machines previously built, but it was easier as I didn't need to play so much with modbus and halui pins). Also I been looking around for exact same issues and couldn't find those.
I will try now myself to solve the issues and not bother people anymore.
Thank you for your help :)
Last edit: 6 years 4 days ago by Varang1an.
  • BeagleBrainz
  • New Member
  • New Member
6 years 4 days ago - 6 years 4 days ago #187537 by BeagleBrainz
Replied by BeagleBrainz on topic Modbus TCP issue with pokeys57E
No no don't be like that. I'm just trying to help users become a little more independent.
Would this have made the initial error easier to find ?
This error is related to not having a Mesa card connected to my machine (it was the easiest way to force an error), but hopefully you get the idea.
Last edit: 6 years 4 days ago by BeagleBrainz.
6 years 4 days ago #187538 by Aciera
What Beagle means is:
Would it have been easier to find the error if you had got this
Debug file information: Note: Using POSIX realtime ./nyx.hal:125: Pin 'modbus.xplus' does not exist 4823 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
at the beginning of the log rather than buried towards the end?
  • BeagleBrainz
  • New Member
  • New Member
6 years 4 days ago #187539 by BeagleBrainz
Actually, on advice from Andy, I just swapped two lines in show_errors.tcl and added a string.
That screen shot is the actual pop up window with the mods that Andy suggested.
6 years 4 days ago - 6 years 4 days ago #187541 by Varang1an
yes, that would been easier. I noticed I had also debug level 3 on modbus... which is way too much info on error report, I swapped it to 2 and directly I noticed modbus ini was ok.
Yes it would been easier to notice if the exact error was in beginning of report :) Anyway now I know where to look and maybe I will start to understand the error log little better.
  • BeagleBrainz
  • New Member
  • New Member
6 years 4 days ago #187543 by BeagleBrainz
Hopefully we can get that into mainline Linuxcnc.
Time to create page: 0.354 seconds
