- Thank you received: 15
Beginner HallUI question
5 years 1 week ago #224262
by mBender
Replied by mBender on topic Beginner HallUI question
I am sorry, I still can´t get it to work. I have a float from my custom panel connected to halui.axis.jog-speed. Furthermore I set halui.axis.z.select 1 and connected the two buttons to halui.axis.z.plus and minus. I see in the Hal Configuration that all signals are working, but the machine is still not moving. It works fine when I use the jog buttons on the Axis GUI.
Here is the configuration in the postgui.hal
# connect the Z pyVCP buttons
net my-jogzminus halui.axis.z.minus <= pyvcp.z-minus
setp halui.axis.z.select 1
net my-jogzplus halui.axis.z.plus <= pyvcp.z-plus
# connect the pyVCP jog speed slider
net my-jogspeed halui.axis.jog-speed <= pyvcp.jog-speed-f
5 years 1 week ago - 5 years 1 week ago #224268
Replied by andypugh on topic Beginner HallUI question
Is the machine homed?
Before homing you can only jog in joint mode (ie, using the halui.joint.jog... pins)
If Axis is showing joint numbers rather than axis letters during your test then that will be the issue.
(If you want to jog in both modes, then
is valid syntax to drive both pins.
net my-jogzplus halui.axis.z.plus halui.joint.2.plus <= pyvcp.z-plus
Last edit: 5 years 1 week ago by andypugh.
5 years 1 week ago #224281
by mBender
My machine is not homed. But it shouldn't be necessary to home the machine, since I can use the axis button to drive the machine Z axis. (I only test the Z axis at the moment )
I tried already what you said with connecting halui.joint.2.plus <= pyvcp.z-plus without the addition of halui.axis.z.plus. It didn't work.
Now, I just tried exactly your suggestion net my-jogzplus halui.axis.z.plus halui.joint.2.plus <= pyvcp.z-plus and I see the pins in Hal Configuration act as they are supposed to be, but the machine does not move.
In the documentation it says halui need to find the nml find specified in the INI. Neither in the INI nor in the config folder I see anything like an NML file. Could that be the issue?
5 years 1 week ago #224286
As well as operating the joint / axis jog+ you might also need to set the halui.joint.jog-speed pin too.
The Axis GUI swaps from joint to axis automatically. That might be the difference.My machine is not homed. But it shouldn't be necessary to home the machine, since I can use the axis button to drive the machine Z axis. (I only test the Z axis at the moment )
5 years 6 days ago #224452
by mBender
Got it working. Thanks
1 year 7 months ago - 1 year 7 months ago #324305
by mtbbiker
Replied by mtbbiker on topic Beginner HallUI question
This work perfectly for me using version 2.9 (Thanks a mil JT !!) My setup uses a Logitech (old) Xbox USB controller to work
Last edit: 1 year 7 months ago by mtbbiker.
Time to create page: 0.204 seconds
