(SOLVED) Max Velocity Selector Switch
4 years 10 months ago - 4 years 10 months ago #229946 by spumco
I think that makes sense now.  I just need to change the inXX
Here goes nothing...
EDIT
Ok, that did the trick to get the values matching the switch positions.
Next problem is that halui.max-velocity.value isn't changing even though halui.max-velocity.scale is changing when the selector is switched.
The only thing that changes the .value is moving the screen slider.  I wonder if the Probe Basic max-vel slider is interfering with the mux16 output?
Last edit: 4 years 10 months ago by spumco. Reason: Fiddling & testing
4 years 10 months ago #229949 by cmorley
halui.max-velocity.scale shouldn't change, halui.max-velocity.counts should change.
4 years 10 months ago #229950 by cmorley
or i guess you could set the counts to 1.
counts* scale = output
4 years 10 months ago #229958 by spumco
Counts is set to 1, and scale is changing per switch position.  Output is changing... but the max velocity value does not change.
4 years 10 months ago #229981 by cmorley
can you post the relevent file please?
4 years 10 months ago - 4 years 10 months ago #229994 by spumco
Sure, thanks for taking a look at it.
I'll probably want to add the mux16.N.suppress-no-input function and change in1 to 0 and so forth.  The selector has dead-spaces between the contacts and I think it'd be annoying to have the velocity change to 0 between contacts.
But that can wait until the fundamentals get worked out.
Time to create page: 0.071 seconds
