Where should I find the config.ini file?
4 years 4 months ago #245423 by SimonCNC123
Hi Folks, I am running Linuxcnc on Debianedu and am trying to setup an Xbox360 controller using this tutorial: www.sdoherty.com/2020/07/using-xbox-cont...r-with-linuxcnc.html
I get everything up until I have to add some code to the 'config.ini' file. I can't seem to find this in my config, an I supposed to create a new file?
Thanks S
4 years 4 months ago #245424 by phillc54
The following user(s) said Thank You: SimonCNC123
4 years 3 months ago #246863 by Todd Zuercher
If your machine's config is called "my_machine" the config file should be:
~/linuxcnc/configs/my_machine/my_machine.ini
Time to create page: 0.129 seconds
