- Thank you received: 20
XHC_HB04_CONFIG - ini file posted
- eriksalo
- Topic Author
4 years 18 hours ago #255806
by eriksalo
XHC_HB04_CONFIG - ini file posted was created by eriksalo
I posted a video on youtube some time ago showing how I implemented the config .ini file for my XHC_HB04 pendant.
Someone requested I post the .ini file. Here it is....
The following user(s) said Thank You: tommylight, smc.collins, LPMattei
- MaHa
- Thank you received: 241
4 years 17 hours ago #255807
by MaHa
Replied by MaHa on topic XHC_HB04_CONFIG - ini file posted
If you want to use the "mode" button to switch to manual mode for jog:
# Switch to mode.manual
net man_mode <= xhc-hb04.button-mode => halui.mode.manual
4 years 16 hours ago #255812
Replied by tommylight on topic XHC_HB04_CONFIG - ini file posted
Should have also posted a link to the video.
- LPMattei
3 years 11 months ago #255863
by LPMattei
Replied by LPMattei on topic XHC_HB04_CONFIG - ini file posted
Thank you, I was the one that requested it. It was the first explanation I somewhat understood. I have been struggling on this for some time. I wish there was a "installing xhc pendant for dummies" file somewhere, that explained files needed, files to modify, where they are located, how they interact, etc
- LPMattei
3 years 11 months ago #255864
by LPMattei
Would that go in the [XHC_HB04_CONFIG] section?
- LPMattei
3 years 11 months ago - 3 years 11 months ago #255867
by LPMattei
ericsalo, thank you. I have mpg responding, although it doesn't seem to have all functions. I think maybe because of all the lines I had to comment out in the xtc-hbo4 hal to get it to even come up originally, I will un comment them and try again. 2 questions, 1, what version of linuxcnc are you using this on, and 2, can you post your xhc-hb04.hal?
edit, I un-commented lines that were giving issue earlier, they no longer a problem, but I still have mpg functions that dont respond.
Last edit: 3 years 11 months ago by LPMattei.
Time to create page: 0.053 seconds
