dbouce.so: cannot open shared object file
3 years 7 months ago #266714 by Tilman
after loading dbounce in my machine.hal, LinuxCNC exits with the following error message:
dbounce: dlopen: /usr/lib/linuxcnc/modules/dbounce.so: cannot open shared object file: No such file or directory
All other realtime components load fine so far. I checked the path but dbounce.so is present at /usr/lib/linuxcnc/modules/.
The error shows up as soon as I try load the component with
loadrt dbounce names=dbounce_probe
The machine runs fine now for 3 years. LinuxCNC is 2.8 on Debian 9.13.0. My "old" config can be found here but it doesn't include the changes I just tried to make: github.com/hausen8/AL_1105
Any help is appreciated,
Tilman
3 years 7 months ago #266912 by andypugh
I am unclear why dbounce might not be working, but you could use the (older, similar) "debounce" instead.
3 years 7 months ago #266929 by Tilman
Well, I could but since I called all components with names, I would like to keep this order. I just had the idea to check owner and rights, assuming that all modules shold have the same owner/group/permissions.
What if I copy dbounce.so from another computer with LCNC 2.8 into this folder? Could this work?
3 years 7 months ago #266938 by andypugh
Well, because you used names= you can (probably) just change the loadrt dbounce names=.... to loadrt debounce names=...
3 years 7 months ago #266948 by Tilman
Surely not because debounce will be loaded with filter groups (loadrt debounce cfg=N,N).
But you're right: Instead of wasting time trying to get dbouce working I should rather give debounce a try.
3 years 7 months ago #266952 by andypugh
You can check it very quickly.
halrun
loadrt debounce cfg=2,2
exit
If that doesn't error, then it's worth continuing.
Time to create page: 0.058 seconds
