dbouce.so: cannot open shared object file
- Tilman
- Thank you received: 7
14 Mar 2023 18:24 #266714
by Tilman
dbouce.so: cannot open shared object file was created by Tilman
after loading dbounce in my machine.hal, LinuxCNC exits with the following error message:
dbounce: dlopen: /usr/lib/linuxcnc/modules/dbounce.so: cannot open shared object file: No such file or directory
All other realtime components load fine so far. I checked the path but dbounce.so is present at /usr/lib/linuxcnc/modules/.
The error shows up as soon as I try load the component with
loadrt dbounce names=dbounce_probe
The machine runs fine now for 3 years. LinuxCNC is 2.8 on Debian 9.13.0. My "old" config can be found here but it doesn't include the changes I just tried to make: github.com/hausen8/AL_1105
Any help is appreciated,
Tilman
Tilman
17 Mar 2023 07:35 #266912
Replied by andypugh on topic dbouce.so: cannot open shared object file
I am unclear why dbounce might not be working, but you could use the (older, similar) "debounce" instead.
- Tilman
17 Mar 2023 13:19 #266929
by Tilman
Replied by Tilman on topic dbouce.so: cannot open shared object file
Well, I could but since I called all components with names, I would like to keep this order. I just had the idea to check owner and rights, assuming that all modules shold have the same owner/group/permissions.
What if I copy dbounce.so from another computer with LCNC 2.8 into this folder? Could this work?
17 Mar 2023 14:43 #266938
Well, because you used names= you can (probably) just change the loadrt dbounce names=.... to loadrt debounce names=...
- Tilman
17 Mar 2023 17:58 #266948
by Tilman
Surely not because debounce will be loaded with filter groups (loadrt debounce cfg=N,N).
But you're right: Instead of wasting time trying to get dbouce working I should rather give debounce a try.
17 Mar 2023 18:41 #266952
You can check it very quickly.
halrun
loadrt debounce cfg=2,2
exit
If that doesn't error, then it's worth continuing.
halrun
exit
- Tilman
16 Aug 2023 01:30 #278122
by Tilman
I almost forgot this topic but I should post at least what was wrong:
In fact dbounce.so was missing. Adding the module solved the problem. Besides I know two more cases with missing dbounce.so. At least in one case it was LCNC 2.8.4, like in my case. Is it possible that in 2.8.4 this module is simply missing?
Kind regards,
Tilman
Kind regards,
Tilman
- phillc54
- Thank you received: 2100
16 Aug 2023 02:03 #278129
by phillc54
Replied by phillc54 on topic dbouce.so: cannot open shared object file
Time to create page: 0.355 seconds
