New GPIO driver for OPI5
3 years 5 months ago #270704 by Guglielmi
I'm trying to create a new gpio driver for Orange PI5 due to the fact ARISC driver is not updated and no other existing driver found.
I'm not so sure I'm able to win on this task.. but, let's try.
I have a basic issue and searching on the web I did not found a solution.
I created a kind of empty C driver starting from  HAL skeleton.
I built it with HALCOMPILE and I got the file.so I called hal_op5_io.so. (I found the name should have max len..)
I placed the file into folder "usr/lib/linuxcnc/modules/".
When I call with "loadrt" my module:
loadrt hal_op5_io addf hal_op5_io.write base-thread
I get an error that module is not found.
I thought it was an error caused by internal code somewhere, so I did another test:
copied all code from hal_parport and just changed file name and the init call, passing my name (hal_op5_io)
but I got the same error.
Found file(REL): ./cnc3040.hal hal_op5_io: dlopen: /usr/lib/linuxcnc/modules/hal_op5_io.so: cannot open shared object file: No such file or directory ./cnc3040.hal:2: waitpid failed /usr/bin/rtapi_app hal_op5_io ./cnc3040.hal:2: /usr/bin/rtapi_app exited without becoming ready ./cnc3040.hal:2: insmod for hal_op5_io failed, returned -1 Shutting down and cleaning up LinuxCNC... Note: Using POSIX realtime LinuxCNC terminated with an error.  You can find more information in the log:     /home/andrea/linuxcnc_debug.txt and     /home/andrea/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
I can get the same identical error calling a non existing module, like calling "hal_mod_fake".
But the file .so exists in the folder!
Should I install somehow or add this module name somewhere else?
Andrea
3 years 5 months ago #270751 by Guglielmi
Replied by Guglielmi on topic New GPIO driver for OPI5
I found the issue!
I was building the driver on a VM with Ubuntu and copying the .so file generated to OPI5.
Now I tried to clone the dev repo inside the OPI5 and build the driver on it and it worked.
I mean.. launching the application now I get errors from the code not written yet, but at least
the system can see and use it.
Good starting point!
3 years 5 months ago #271090 by mwidlok
Replied by mwidlok on topic New GPIO driver for OPI5
Guglielmi,
Have You checked latency on the OPI5?
I really would like to compare it with old H3, that I've used before. It was not great if I remember correctly.
3 years 5 months ago #271165 by Guglielmi
I will post a screen-shot as soon as I back at home.
I remember it was around 3us running for more than 2000 seconds, with 6 gears running
How much you can reach with H3?
3 years 5 months ago #271253 by Guglielmi
Attached a Latency test with Wifi active and 6 Gixgears
3 years 5 months ago #271262 by rodw
Replied by rodw on topic New GPIO driver for OPI5
Amazing!
Time to create page: 0.101 seconds
