- Thank you received: 5
...and it works fine to stop the machine and produce an error message. What I'd like to change is the reset. After rebooting the amp(s) and clearing the fault, Linuxcnc holds onto the fault condition (gmoccapy), and the machine won't turn on. I need to close and restart lcnc.# --- X drive ALM ---
net x-fault => joint.0.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-16-not
# --- Y drive ALM ---
net y-fault => joint.1.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-17-not
# --- Z drive ALM ---
net z-fault => joint.2.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-18-not
