RPI4b Revision 7 not supported by HAL_PI_GIO
3 years 3 months ago #275580 by itsme
I now tried the given workaround and this works well with the unmodified HAL_PI_GPIO.
Thank you!
3 years 3 months ago #275585 by itsme
Unfortunately this workaround is not persistent, after a reboot the cpuinfo is reset by the system and the workaround has to be done again to make LCNC start.
3 years 3 months ago - 3 years 3 months ago #275587 by elovalvo
 [attachment=54524 wrote: startlcnc.txt[/attachment]itsme post=275585 userid=28738"]Unfortunately this workaround is not persistent, after a reboot the cpuinfo is reset by the system and the workaround has to be done again to make LCNC start.
While waiting for Andy to complete his precious work, download this file to the Raspberry then run the following commands:
sudo cp startlcnc.txt /usr/local/bin/startlcnc sudo chmod a+x /usr/local/bin/startlcnc
and LinuxCNC will always start at the command:
startlcnc
File Name: startlcnc_...7-16.txt
File Size:88 B
P.S.  the system changed the file name by adding day and year. Once downloaded rename it startcnc.txt deleting the addition
Last edit: 3 years 3 months ago by elovalvo.
3 years 3 months ago #275597 by itsme
Thank you for your suggestion! I have not tested it yet, but I assume it will not work as expected.
The tmp folder is purged on startup...
3 years 3 months ago #275956 by elovalvo
Yes, indeed tmp folder is purged on startup.
And in fact the procedure copies the file on tmp every time before starting LinuxCNC ...  image missing /media/kunena/emoticons/wink.png
3 years 3 months ago #275965 by itsme
Ok, I miss the part where cpuinfo is changed...
Time to create page: 0.065 seconds
